Vararam C7 True Cold Air!!!
Old 09-26-2017, 05:30 PM
  #41
Foosh
CF Senior Member
Foosh's Avatar
Originally Posted by themonk View Post
what does the air going into the engine have to do with the exhaust coming out?
More air means combustion changes, since it also means more power, and potentially emissions changes. CA is very strict about any changes to OEM configurations.
Foosh is offline
Old 09-26-2017, 05:59 PM
  #42
\Boost Monkey/
CF Senior Member
\Boost Monkey/'s Avatar
Originally Posted by spinkick View Post
Can we buy this without the filter? I'd rathar use a non oil based media. Have you tested with the oem filter or another dry brand?
I could be wrong, but I thought he told me a while back they could use either. My test unit had the oiled filter, but he did give me the option of either and I chose oiled.
\Boost Monkey/ is offline
Old 09-26-2017, 06:42 PM
  #43
Former USMC
CF Senior Member
Former USMC's Avatar
Originally Posted by VaraRam Industries View Post
The VR system uses airflow from a natural high-pressure zone that draws air from Outside the engine compartment. This helps dramatically, feeding cool air to the intake system, to help intercool the intake air charge. The OEM fender area is mostly hot air. Pulling from a small hole and the rear of the front fender back by the sump tank from under the hood! This has played havoc for Z-06 owners!
It is the only system to use a precision injection molded elliptical Airbox Tail and MAF block to ensure precise and consistent MAF sensor metering. Most others use Rotational molding and that is not a precise molding process when it comes to holding tolerances on bore ID s.
Systems like that usually require custom tuning because no two kits are ever alike.
As for airflow, the VR flows far beyond the number you posted.
The VR system also uses venturi areas in the intake system to produce a velocity spike at a specific RPM point to force air into the intake system under vacuum! We went through allot of testing to make that happen. This shows up when we do flow bench testing as well at specific flow points. We did the same thing on the DRX Camaro system to boost power under the curve to great effect. We flow test through the cylinder head, intake manifold and throttle body as one unit. We also conduct a standard flow test but those types of tests never show you the true picture.
Our web guys will be putting up the flow graphs in the next few days, as well as a flow video.
The VR TCR-7 was meant from day one to be a tuned intake system, using every trick possible to boost flow and thermal efficiency with a minimum of extra components to add unnecessary extra cost. NO CORVETTE premium!
The philosophy was: Keep it simple and get the job done as efficiently as possible to make Vararam equipped C-7s consistent and fast!
VR tech
VR,
First of all, I'm not trying to be a wise guy...I just want to see a comparison between your CAI system and AFE or K&N. You stated in your ad that your system outflows and outperforms the competition - guaranteed. Well, let's see how much hp and torque your system produces versus AFE and K&N.
Words like: high pressure zones, injected molded elliptical Airbox, velocity spikes are nice terms but how do they translate to performance.
Again, not trying to be difficult, but compare your CAI system - specifically: HP, Torque, and CFM to the competition.
The only numbers I've seen is horsepower...you claim a 18-20 increase. AFE claims 18. Why does your system have a range? Different cars, different tests, if so, what's the average?
Thanks,
Semper Fi
Former USMC is offline
Old 09-26-2017, 06:50 PM
  #44
spinkick
CF Senior Member
spinkick's Avatar
Exactly, show us using an oem filter after using the same filter stock back to back. Also, where does the moisture go from the cold air coming from the crack in the hood, and what kind of dirt comes from the filter sitting inside the fender area?
spinkick is offline
Old 09-26-2017, 09:23 PM
  #45
VaraRam Industries
Supporting Vendor
VaraRam Industries's Avatar
St. Jude Donor '07-'11-'12
The oil is air sensor safe. Green filter is one of the few high performance filters to be used as OEM by several major manufacturers for this reason. They do not use a heavy silicone based oil, other companies do and this is what sticks to the MAF wires and causes codes.
VaraRam Industries is offline
The Following 2 Users Say Thank You to VaraRam Industries For This Useful Post:
Chuck CoW (10-04-2017), spinkick (09-26-2017)
Old 09-26-2017, 09:53 PM
  #46
cheapthrills
CF Senior Member
cheapthrills's Avatar
Following along, haven't been a CAI believer yet but hey I'm open to change.
cheapthrills is offline
Old 09-26-2017, 11:23 PM
  #47
VaraRam Industries
Supporting Vendor
A Tuned Induction system is what we produce, not just a CAI.
The stock fender volume is restrictive , so the C-7's naturally pull hot air from under the hood back by the sump tank. We pull enough cool air from the second high pressure location to aid in both intercooling of the air charge and increasing our effective plenum volume. Combining Those features along with the velocity manipulation from the internal aerodynamics of the intake systems design and it all adds up to producing some real world HP you can feel, to an otherwise stock car.
The Following User Says Thank You to VaraRam Industries For This Useful Post:
Old 09-26-2017, 11:30 PM
  #48
juanvaldez
CF Senior Member
I ordered one yesterday. It will be here tomorrow.
juanvaldez is online now
Old 09-27-2017, 12:01 AM
  #49
pharaoh4269
Junior Member
Default Rain
Same question as Spinkick above. Any issues running the VR in the rain/downpour?
As noted in the description:
"The VR system uses airflow from a natural high-pressure zone that draws air from Outside the engine compartment. This helps dramatically, feeding cool air to the intake system, to help intercool the intake air charge."
Some of us do let 'em see the wet stuff!
pharaoh4269 is offline
Old 09-27-2017, 11:26 AM
  #50
VaraRam Industries
Supporting Vendor
No issues at all.
I even drove my car at the start of Hurricane Harvey. Mainly because I was trying to get home in the middle of the night before the streets by our facility flooded !
VR tech
Old 09-27-2017, 09:16 PM
  #51
Zap City
CF Senior Member
Zap City's Avatar
St. Jude Donor '13
Mine arrived today. Thanks for the excellent customer service. The quality looks fantastic. Looking forward to dropping it in this weekend and seeing how she does.
Zap City is offline
Old 09-27-2017, 09:58 PM
  #52
juanvaldez
CF Senior Member
Got mine today. Nicely made, good instruction. I plan on putting it on tomorrow.
Quick question, is the filter pre-oiled?
Old 09-27-2017, 10:11 PM
  #53
VaraRam Industries
Supporting Vendor
Yes it is . We specify the clear oil rather than the Green colored oil.
It just looks better that way when you have a filter you can see when the hood is open.
It would look bad if you had a Blue car and Green colored filter.
For those that want to, they can buy colored dyes for the Clear Green filter oil to color match the filters to their cars.
WE stock the Green filter cleaning kits in Clear vs Green 24/7.
VR tech
Old 09-28-2017, 05:54 PM
  #54
spinkick
CF Senior Member
spinkick's Avatar
VR tech
Do you have to use the green filter, can you use a different filter? I have a BMS filter that I like.
spinkick is offline
Old 09-28-2017, 08:29 PM
  #55
Mike Campbell
CF Senior Member
Mike Campbell's Avatar
My C6 Vararam had a green filter and what I did was buy another one and every year in March I'd take one out and put in the cleaned other one. It made a .5 sec. difference in my car's consistent 1/4 mile times. Just saying! So I will be getting their new one for my C7.
Mike Campbell is offline
Old 09-28-2017, 08:43 PM
  #56
spinkick
CF Senior Member
spinkick's Avatar
The c7 oem intake is pretty damn awesome, stock vs the restrictions the c6 one had. I'm trying to get more data out of them on all this.
spinkick is offline
Old 09-28-2017, 09:24 PM
  #57
phil hunter
CF Senior Member
phil hunter's Avatar
How hard is this to install. I had a C5 and put a Vararam on it. While it worked well, it was a PIA to install. Also, when/if you get CARB certification will it be possible to get the CARB sticker after the fact if I purchase one now?
Phil
phil hunter is offline
Old 09-28-2017, 09:33 PM
  #58
juanvaldez
CF Senior Member
I'm putting one on as we speak. Might take me two hours because I'm slow.
Old 09-28-2017, 09:38 PM
  #59
VaraRam Industries
Supporting Vendor
The Green filter was designed from day one to our Specs. It has a much lower pressure drop across it than other filters.
By "Other" I mean all brands.
Regarding the filter you have, The leading filter Brand as they say on their website prob starts with the letter K in its name.
That is all well and great, except the Brand "K" filters average a 55-50% pressure drop across their flow path. The stock paper filter has a 60% pressure drop across it.
The Green Filter is on another planet compared to those numbers.
If you change the pressure drop inside any induction system you are changing the volume and velocity at each given RPM point.
Your throwing off the entire aerodynamic package as it was designed and in this case you would be restricting the system.
Defeats the purpose !
VR tech
Old 09-28-2017, 10:26 PM
  #60
VaraRam Industries
Supporting Vendor
NO issues , I drove my personal car In Hurricane Harvey 40 miles round trip to our shop and back in the middle of the night at 50mph. I could barely see to drive and the car was hydroplaning etc.. ( Alarm went off at our production facility)
We have been testing this unit in just about every weather condition you could imagine for 2 yrs covering thousands of miles without issue.
As an added bonus I just drove my car home in Houston, In the rain, in traffic for an hour and change today! ( washed it a couple of days ago, go figure?)
Again, no issues. It was designed to be used in all weather conditions.
There are many manufacturers who use high pressure zones like this one, some even face directly forward, and are ram air systems. examples: Mercedes Benz , Porsche, VW, Ford etc...
They use them on everything from SUV's , performance cars even the Ford F250 Turbo Diesel truck.
MB GLC example :
Quick Reply: Vararam C7 True Cold Air!!!
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
