Best adhesive remover for removing badges
Fellas,
Looking to swap out the chrome badges with carbon flash. I've read a few threads on the topic and curious as to what is the most effective adhesive remover BUT also safe on the paint. Someone even mentioned using WD-40 and letting it sit for over 30 minutes, but it came right off without any residue, and he didn't even use a heat gun or floss. By the way, is a heat gun or blow dryer going to cause any issues?
So which is most effective AND safe on the paint. Here were some suggestions:
Goo Gone
WD-40
3M Adhesive Remover
Citrus Cleaner
Any other suggestions?
Thanks!
Goo Gone
WD-40
3M Adhesive Remover
Citrus Cleaner
Thanks!
I don't know which is the most effective, but I used Goo Gone when I took off my badges. Took about 5 minutes a badge using Goo Gone and no damage to the paint. I removed as much of the black adhesive first by hand and then used the Goo Gone.
I just used dental floss to remove all the badges. I did not use any heat. It took about 2-3 minutes to get each badge off.
Comebackid (09-26-2017)
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
FWIW, been using 3M adhesive remover for years. Sold in auto paint stores for paint prep. Works on silicone etc etc. Won't harm paint.
The following 2 users liked this post by JerryU:
Comebackid (09-26-2017),
gesystem (03-04-2020)
Goo gone
rubbing alcohol works and its cheap
Received 5,207 Likes
I have had problems with 3M Adhesive Remover on some paints and would test it on ANY such finish before just assuming it would be okay. Goo Gone is pretty harmless but from my experience with several brands of auto badge adhesives it does take time and elbow-grease, plus a constant new rag/towel surface to prevent simply smearing the adhesive residue around. But, as I say, I think it's the most harmless for most, if not all, finishes. I've never used the citrus, so I cannot speak to it.
The following 2 users liked this post by Kevin A Jones:
JerryU (09-26-2017)
I used goo gone for two reasons. I already had it and it's known to be paint friendly.
Comebackid (09-27-2017)
I second using a purpose-made adhesive remover. Googone/alcohol are not very effective and may lead to your paint getting scratched in frustration trying to get it off. Ask me how I know..
The following 2 users liked this post by chronage:
Comebackid (09-27-2017),
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
I use Goof Off. Strong stuff, works fast, but didn't hurt the paint on our Lexus. I haven't tried it on the Corvette yet. I always wash off with water whenever using any solvent, then immediately wax the surface when finished.
The following 2 users liked this post by roadbike56:
Kevin A Jones (09-27-2017)
I have used my wife's hair dryer to remove emblems off my vehicles with no damage just concentrate the heat on the emblem and it will come off in no time. And no damage to any surrounding areas. I have used mineral spirits to remove any residual adhesive also with no paint or clear coat damage.
I use acetone.
I've been using it on both factory paint and auto body paint with no damage for over 20 years. It will remove touch-up paint right quick, however.
As others have said, wash/rinse the area immediately, no matter which method you use.
Comebackid (09-28-2017)
Emblem Removal
A professional grade wax and grease remover like PPG DX 330 works well, just have to let it soak into and loosen the adhesive before removing the emblem. As noted, dental floss or nylon fishing line can be used to saw the emblem off as well. Just make sure the area behind the emblem is clean if you do this, otherwise dirt and any grit trapped there will scar the paint.
Received 19,284 Likes
'20-'21-'22-'23-'24
3M or Goo Gone would be my choice.
