Contemplation
Contemplation
I am contemplating on an upgrade. Do the C7's come with a Targa top. I have not seen that option
CPO Rob
CPO Rob
CPO Rob (09-28-2017)
Moderator
It is not an option, it is standard on all versions of the coupe (Stingray, GS, Z06).
That's a good sign when folks can't totally tell that the top comes off on all of them. I personally like the profile lines of the coupe better and the fact that the tops come off gives you a little of both worlds....
The following 4 users liked this post by mountainears:
Mostly agree
It is a better looking car as a coupe (and I have a '14 Vert.) BUT having come from a coupe, the top off in the coupe is not nearly as immersive/comfortable as a vert; with the targa roof off the air swirls around and has no where to go and kind of beats you up when you get above 45 or so, the full vert brings in all the light and there is a lot less being slapped around......
The following 3 users liked this post by dbirdhouse1:
CPO Rob (10-01-2017)
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
Not only does the roof remove, as it did in my C6, it has a place to store it in the rear!
Drive down to Atlantic City and look at the hundred+ Kerbeck has in stock. As Howard Carter said when looking through a small hole in Tutankhamen's tomb for the first time and asked, "Can you see anything?" You'll say the same as him, "Yes, wonderful things!"
They are the largest Corvette dealer in the country for a reason! Typically sell ~25/week! I drove a bit further from SC to pick up my '08!
Bought my Grand Sport from them as well. Great folks.
C7 coupe with roof removed! It's carbon fiber and lighter than the C6! Easy off and stored in rear.
I waffled on this for a year before making a decision. It's definitely better looking as a coupe. I drove convertibles for 12 years and my opinion is that having the roof off is 50-60% as immersive as having the top down. Wind isn't an issue for me as the majority of my driving is not on freeways. The final deciding factor for me was not being able to track a convertible. If I didn't have intentions of tracking my car, I don't know what my final decision would have been.
St. Jude Donor '13
I would agree with this about the buffeting not being nearly as bad as its made out to be by the vert guys. I take mine off way more than I thought I would. I've owned verts over the years and can't see going back ever based on how nice the targa is.
I'd never go back to a coupe for street use. What's the point?
I do like the rear quarter view of the coupe's lines, but from other angles, and in particular from the driver's chair (sound, view, fury) the convertible can't be beat. A targa gives you some of the open air feel, but not the top-down feel, nor the sound with the top down, nor even the quiet with the top up (better insulation in the 'vert). Just my two cents... buy the one -you- like.
On the track, you want a coupe, even though I've tracked this vert... not the hot ticket.
The following 2 users liked this post by davepl:
CPO Rob (10-01-2017),
Skid Row Joe (09-29-2017)
I had a '16 Stingray Convertible and now have an '18 Z06 Coupe. The Convertible does have a better open air driving experience, but I find the top off on the Coupe is very enjoyable too. i really don't notice this wind buffeting like many do. Maybe the partition I have makes a difference. Convertibles are $4000 more than Coupes in all models.
St. Jude Donor '17, '19
Soft tops are easily broken into, wear out, make it harder to keep the car warm/cool, and eventually leak. I have seen it on every daily driver I have ever been exposed too. So unless it is going to be a garage queen, I will always have hard tops.
The buffeting is only bad on the highways. In all other conditions its great.
Corvette Enthusiast
Technically you could remove the "top" in C3s. The T-tops were removable too. It's been around for a while. And I love it.
Sounds like you are not very familiar with C7 convertible tops.
The following 3 users liked this post by Kevin A Jones:
[QUOTE=Woodson;1595666985]More info please?
I bought this partition from Exotic Corvette ( Crazy Cowboy) custom made for C7 Coupes. It partitions the interior from the trunk. It works well with the two piece cargo cover and the removable roof panel. I think it cuts down a little of the wind buffeting with the top off and helps the rear radio speakers sound. Pictured with top installed in trunk other with top on car.
Woodson (09-29-2017)
