FYI Bluetooth connectivity
Anyone experiencing issues with connection to Bluetooth, there is a temporary TSB solution. Basically saying to go to Settings screen and select Return to Factory Settings / Delete Data then to re-pair new device. That did not work in my situation and I found out that I also had to delete the My Chevy My Link from the phone as well then you can re-pair new device..
No bluetooth connection problems here 2017 Stingray 1LT.
Actually it is too good. When I go to the garage and put the car in acc mode, it connects to my phone in the kitchen about 20 ft away through 2 walls.
