C7 used buyers guide
St. Jude Donor '17, '19
Hey Guys,
I didn't see a sticky on this so I thought I would get some advice.
Looking at a used vette, coupe. What should I ask, look for, and check on?
Here is my list at the moment:
- Carfax and frequency of maintainence
- VIS report to see what warranty and recalls have been done
- view window sticker or build sheet to make sure the car has the options that are stated
- if not buying from a dealer, check the VIN with the local police to make sure its not stolen (far fetched, but I have read a few stories recently)
- Chevy dealer inspection
---> ensure ECU pull to see if engine was tuned or something would void the warranty
- Look at signs for water damage in the carpet and under the car
- listen for a dreaded t-top rattle
- check the display for signs of cracking or going black
- (if auto) listen for any issues in shifting
- side bolster wear from poor exiting technique
- fender walls for stuck-on rubber splatter (burning out evidence)
- tire life
- oil level after test drive (wait for the oil to get up to operating temperature)
Anything else?
z51 specific things to look for?
--> if the oil was NOT changed at 500 miles, should that be a deal breaker? (assuming not on the carfax)
Magride specifics to look for?
- tire life
Anything else?
Some guys have mentioned to check the fender wells for stuck on spatters of rubber. They say indicative of track use, and rear with lots of rubber chunks could mean a lot of trips down the 1320.
Have Chevy dealer pull entire service/maintenance history.
Also have them check the ECU for any flashings or reflashings so you can see if it was ever tuned and would have the powertrain warranty voided.
--> if the oil was changed at 500 miles, should that be a deal breaker? (assuming not on the carfax)
wouldn't that be a good thing? or do you mean not changed at 500 miles
I would possibly add tire wear, and definitely have it inspected
Hey Guys,
- Chevy dealer inspection (maybe)
Anything else?
Anything else?
Example:
05/29/2014------27------Riverton Elko GM Superstore Elko, NV 775-738-5131 rivertonelko.com------Vehicle sold
06/02/2014---------------Nevada Motor Vehicle Dept. Elko, NV-------------------------------------------Registration issued or renewed
06/25/2014------251-----Riverton Elko GM Superstore Elko, NV 775-738-5131 rivertonelko.com-----Maintenance inspection completed, Electrical system checked
06/26/2014---------------Nevada Motor Vehicle Dept. Elko, NV-------------------------------------------Title #NV007046746-1 Title issued or updated - First owner reported - Titled or registered as personal vehicle Loan or lien reported
08/14/2014------2,525---Riverton Elko GM Superstore Elko, NV 775-738-5131 rivertonelko.com-----Maintenance inspection completed, Steering/suspension checked
08/15/2014---------------Riverton Superstore - Chevrolet Sandy, UT 801-576-4600 rivertonchevy.com------Vehicle serviced
12/15/2014------3,334---Riverton Elko GM Superstore Elko, NV 775-738-5131 rivertonelko.com------Maintenance inspection completed, Oil and filter changed
Yes, that was a typo. I updated it. Would it be bad it there was not a service record for a 500 mile oil change?
Example:
Example:
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
If the car you're looking at did not have the oil changed at 500 miles, but now has 10K on the clock, I think it's past the point where you have to be concerned. Just my opinion.
If you are looking at a 2014 this is not an issue, but 2015's and later A8 automatics can and do have issues w/ surging and other anomalies.
These issues can be infrequent and random or can occur a lot, but mine started to occur when I did a bit of spirited driving (nothing crazy, just some quicker accelerations w/ some braking and more accelerations) and then resume normal traffic operations.
Surging occurs (for me) when rolling slowly up to stopped traffic, the car will surge or lunge forward before coming to a complete stop. Some can be fairly mild other can feel like someone behind you hit the car in the rear end. You can check for this during a test drive w/o appearing to 'flog" the car.
To: Chevrolet, Buick, GMC, and Cadillac Dealers
2014/2015 Z51 and Z06 Corvettes – Additional Required Maintenance
The following message only applies to dry sump Corvettes that have not had their first oil change performed.
Some 2014/2015 Z51 and Z06 Corvettes may experience a condition that leads to oil leaking out from the air cleaner assembly. This
condition may be caused by running the engine continuously at a high engine speed with the first factory fill oil, resulting in silicone
sealants in the engine’s gaskets degrading the oil’s anti-foaming agents. The oil foam has no effect on the engine’s durability.
Effective Immediately:
GM is changing the required maintenance schedule for all 2014/2015 Z51 and Z06 Corvettes equipped with dry sump systems. The new
schedule will require the oil/filter be changed immediately after the break-in period, which occurs after the first 500 miles of operation.
Once the break-in oil change is performed and the Oil Life Monitoring system is reset, customers should follow the Oil Life Monitoring
system for all future oil change needs.
Received 8,917 Likes
Hey Guys,
- tire life
Anything else?
- tire life
Anything else?
Check behind the front wheel wells, the lower doors, the rockers and the rear quarters for signs of paint chipping. The sides of the car are subject to debris blasting from the front tires and it is a cumulative affect on all cars whether or not they have side skirts and wide mud guards. The chips start as very small barely seen marks in the clear coat but eventually add up to the point the finish looks sort of foggy and when water is run over it the finish looks great.
If the car is a dry sump car run the engine until the oil temperature (NOT the coolant temperature) is above 175 degrees F. Then turn off engine, wait 5 minutes and check the oil level.
As for the dry sump 500 mile oil change some early cars may not have it done as it was something that came about after 2014 cars were being delivered for a while. I know of one 14 Z51 that did not receive the 500 mile oil change since the owner had the car for 6 months or so and several thousand miles and had already received one of the two annual oil changes that were provided for in the price of the car. This all occurred before the 500 mile oil change was introduced by GM. He has almost 20K miles on the car now and the engine is doing fine. I suspect that any car that didn't get the 500 oil change and has a fair number of miles on it by now won't be affected by the problem GM discovered.
Bill
Wheel wells can have smeared rubber stuck in the surface if the car was on the track. Also look under the car as tire rubber will catch in various locations on the frame and floor pan support bars.
Bill
Bill
And what am I looking for? Should it be over the fill line because of heat expansion, smelling it for burning, etc.?
