Changing Driving Mode in a Turn
It is a safer practice, not to change the steering wheel mode in a turn.
Selecting different driving mode changes multiple parameters in C7, including steering wheel ratio and firmness. Sometimes when I am in a ramp merging to a highway I change driving mode from Touring to Sport. After a second or so I feel the steering wheel gets firmer, but ratio stays same. Coming of the ramp, as soon as the steering wheel centers, the ratio changes to sport too. To me, that inconsistent feeling of the steering wheel action in a turn is not safe. Recently I change driving mode only on a straight line and way before entering a turn.
Why would you do such a thing? At low speed I'm sure it's not a problem but no logical reason for it. Too many things change in the handling characteristics to be safe at higher speed. I don't do it.
juanvaldez (10-19-2017)
The steering ratio remains the same regardless of mode, it is mechanically determined and not changeable outside of installing a different rack and pinion. It is variable ratio in that the ratio changes depending upon the distance the wheel is turned either side of center but that is the same regardless of mode and the lock to lock turns of the wheel is invariant across mode.
I agree that changing driver mode during a turn isn't a good idea.
For me touring mode steering offers too much assist so I have it unlinked from driver mode and set to sport at all times.
The following 3 users liked this post by NSC5:
Received 1,620 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
If I am approaching a cloverleaf or long onramp and know that there is no traffic that will impede a spirited jaunt, I will switch to sport mode at least a few hundred yards prior to entering that turn/ramp. I do not think I would ever consider changing it while negotiating a turn.
bimmerborn (10-19-2017)
Probably the biggest risk is not from upsetting the electronics but from taking your hand off the wheel in order to monkey with a ****, looking at the dash for feedback (since you cannot 'feel' the **** change modes reliably), and so on... all in the middle of demanding curve.
I usually get into sport mode on the straightaway heading into this turn and then take the second from the right lane. Often nobody's in that lane. As I enter the turn most of the people in the right lane are slow and leave gaps. If the gap is right I change lanes to the left and if I'm lucky I can easily pass everybody on the highway entrance where the two lane merge to one.
I cannot picture also trying to get into sports mode while turning. I know about this jughandle in advance as it's right by my home and I set the sport mode way before I enter the turn.
Not sure the point of this. If you want to go fast just step on the throttle. On the street I don't see any performance difference between tour and sport. I personally drive in sport the majority of the time. I believe the only time I've used tour was a trip up to Seattle to see if I could feel a difference in the suspension. I also believe Sport mode keeps the exhaust valves open more often. Hence making it sound even better.
The setup options are a little different by year but I have both engine sound management and steering unlinked from driver mode with the sound management either in sport or track mode and steering in sport mode. Although there isn't a huge steering effort difference between tour and sport I find the small difference in effort makes sport mode steering feel far more solid. If the vehicle doesn't have NPP then mode has no effect upon engine sound and without MSRC there are suspension stiffness differences by mode.
Former Moderator
Yes I have a Z with the Z07 package. The car doesn't ride as soft as my previous M3. However even in sport mode it feels better than my 02 Saleen mustang ever did. I guess I'm just used to sports cars riding a bit rough. I guess it's a trade off.
Corvette Enthusiast
You sure its changing in the turn? What's your torque input on the wheel?
When it comes to these drive mode selections in steering there are two schools of though, allow the change when the driver requests it, or ignore the driver and change at the next neutral steering event (on center, low torque)
