Need help with exhaust system issue
Installed LG motorsports long tube headers, xpipe, and cats to stock mufflers. Experiencing a rattle under part throttle acceleration between
1000 and 2500 rpm. Minimal to non existent under full throttle. Made an attempt to change harmonics by wedging a piece of old tire between the
plates that cover the collector, xpipe and cats and the exhaust system. Problem solved but this is not a permanent solution. Looking for some recommendations for a better solution.
Additional info: 1) exhaust seems solid. Nothing loose. All clamps tight.
2) new system is lighter than stock and might be
Moving around more going over bumps
Do you have access to a hoist? Is it possible the clamp bolts in the back of the X pipe are not facing down and are just slightly touching the heat shields under load?
