Purchased Used C7 with Factory Warranty... Found tune after/warranty void
Old 10-26-2017, 08:20 PM
Grimeybob
3rd Gear
Grimeybob's Avatar
Default Purchased Used C7 with Factory Warranty... Found tune after/warranty void
Recently I purchased a C7 with the remaining factory warranty, as well as a remaining certified warranty showing on the Chevy Service Report, from a non GM dealer, out of town... Shortly after, it began having a very loud ticking noise and stopped accelerating. I took it in to get checked out by the nearby Chevy dealer and they found a sunken lifter and loose rods... In addition to aftermarket bolts, denying the warranty. After, they sent the PCM to GM, in which they came back and said the car had been tuned 8-10 times and they would be putting a block on the warranty.
Does anyone know if there are time stamps or mileage stamps on the logs showing the car was tuned? I reached out to the dealer I purchased it from with no luck... Looking at where to go from here.
Old 10-26-2017, 09:40 PM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,066 Likes on 6,168 Posts
Yes, they can tell if the PCM has been tuned, even if it has been returned to stock tune.
Old 10-26-2017, 09:44 PM
\Boost Monkey/
\Boost Monkey/'s Avatar
You want dates to prove to the dealer it was tuned pre you?
I know the system uses a ECM revision counter and that’s how GM knows, but not sure if the revisions are date stamped. I would doubt it.
Old 10-26-2017, 09:48 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
I'm sorry to read of this. From about the mid-C6 run, one of the things learned in buying a used Corvette was to have it checked for a tune. It would cost some money but not nearly as much as having a partial or complete powertrain block. Hope someone can answer your question on here.
Old 10-26-2017, 09:55 PM
mschuyler
mschuyler's Avatar
Received 3,818 Likes on 1,614 Posts
Oops! Sorry, but you're screwed. Doesn't matter if you did not do the tune yourself. It was tuned, therefore warranty is blocked. Not the first time this has happened.
Old 10-26-2017, 10:22 PM
saleen556
saleen556's Avatar
Received 2,200 Likes on 1,191 Posts
Sorry to hear. This is what scared me about buying used. I know there are well taken care cars out there. However I'd probably have this luck had I went used. To many dishonest people.
Old 10-26-2017, 10:25 PM
curve65
curve65's Avatar
Boy, that is a bigtime bummer. You should try and hold the dealer for selling you pig in a poke. If they advertised it as having a warranty, then oopso on them. How long have you had the car?
Hillbilly65
Hillbilly65's Avatar
If he had a way to prove the car was tuned prior to his purchase he may be able to go back to the dealer he purchased it from.
They may have to do something if they failed to tell about the cars history.
Maybe
The following 2 users liked this post by Hillbilly65:
Landru (10-27-2017), Rebel Yell (10-28-2017)
Old 10-26-2017, 10:38 PM
ZenicaPA
ZenicaPA's Avatar
Not if you change the ECM.
Which is what I'd be doing if I were so inclined to tune it.
Old 10-26-2017, 10:46 PM
dmaxx3500
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
Lawsuit time with the dealer you bought it from
Old 10-26-2017, 11:25 PM
spireland
spireland's Avatar
Received 2,147 Likes on 877 Posts
If the dealer had paperwork saying it had warranty remaining, like they do in California, you may be able to hold them responsible for the repair. That stinks.
Old 10-26-2017, 11:50 PM
\Boost Monkey/
ECM/PCM/TCM, it’s all the same module.
This is a good explanation of how the system works:
Originally Posted by wstaab
The flash counter memory segment of ECU stores the calibration ID, programming date (as sent by the programming software) as well as the programming station or repair facility ID from GM MDI unit used.
If a re-flash is done by a third party using a GM TIS subscription the re-flash is stored but does not match any event in the GM vehicle history data base.
If aftermarket software is used the info is blank but the re-flash is stored.
GM can look at the vehicle history data base and see how many re-flashes were done by an authorized GM dealer
If you re-flash your OEM ECU you risk voiding the factory warranty if you have a mechanical problem with the powertrain.
The following 3 users liked this post by \Boost Monkey/:
DALE#3 (10-27-2017), Foosh (10-27-2017), Zymurgy (10-26-2017)
Old 10-26-2017, 11:54 PM
LT1pwrd'94
LT1pwrd'94's Avatar
I had similar issue 2 weeks ago. Scroll back a lil here in general discussion and check my thread out.
I’ll be ordering new short block tomorrow(I believe) from Texas speed and performance, my heads survived.. they’ll get cnc treatment and whole new upgraded valvetrain. Some other misc parts and hopefully I’ll have her back by early December..
Old 10-27-2017, 12:01 AM
Zymurgy
Moderator
Zymurgy's Avatar
I believe this is the thread LT1pwrd'94 is talking about: Bought low mile '14 coupe 3 wks ago, motor just blew..
LT1pwrd'94 (10-27-2017)
Old 10-27-2017, 12:03 AM
Foosh
Foosh's Avatar
Received 16,667 Likes on 8,311 Posts
LOL . . . that would just add to your out-of-pocket expense in addition to paying for your engine replacement/repair. They'd know you did that as well.
Let me get this straight, your plan would be to purchase another ECM which you would tune? Then, you'd plug in your original factory, unmolested ECM back in after you experienced an engine problem? And, you don't think they'd notice the fact that your original, unmolested ECM has no recent data recorded?
Good luck with that approach.
DALE#3 (10-27-2017)
Old 10-27-2017, 12:47 AM
z06inVB
z06inVB's Avatar
Received 1,103 Likes on 518 Posts
Would the tune void the entire warranty or just power train ?
Old 10-27-2017, 12:54 AM
Foosh
Foosh's Avatar
Just power train, but that would include all components associated with the engine and transmission.
To Purchased Used C7 with Factory Warranty... Found tune after/warranty void
Old 10-27-2017, 09:52 AM
DALE#3
DALE#3's Avatar
Received 3,129 Likes on 1,828 Posts
Exactly...Sucks to go threw this expense.We are purchasing a Race Car,Used.A dice roll for that Garage Queen..
This is why as mentioned,Check the Car out first.
Warranty is HUGE when spending the Big Bucks..
Old 10-27-2017, 10:27 AM
John Ulrich
John Ulrich's Avatar
I commend you on your manner. You got served some lemon and instead of drama you're moving ahead and making lemonade!
The following 2 users liked this post by John Ulrich:
Gonzo (10-27-2017), LT1pwrd'94 (10-27-2017)
Old 10-27-2017, 11:21 AM
yeller z06
yeller z06's Avatar
Aside from the tune, the OP wrote something about "aftermarket bolts" which I take to mean that there was some internal engine work done as well.
Although the selling dealer was probably totally ignorant and technically innocent in this, I don't see why you can't at least try to get them to share some of the cost for repairs.
Best of luck.
The following 3 users liked this post by yeller z06:
Gonzo (10-27-2017), Hopper12 (10-27-2017), Rebel Yell (10-28-2017)
Quick Reply: Purchased Used C7 with Factory Warranty... Found tune after/warranty void
