Low Profile jack to lift in the center front?
I would like to lift both wheels by using a jack in the center lifting point in the front of the car. My Harbor Freight jack will make it under the front of the car lifting point but I can't pump the handle because the car is too low in the front. Is anyone using a jack that can reach the front lifting point and still have clearance to raise the jack handle? Thanks
If you are already using this one
https://www.harborfreight.com/2-ton-...ump-60678.html
The first thing that comes to mind, and I use, as a cheap fix, is a couple of 2x10’s or 12’s as ramps under the tires to help get it started.
georgehafe (11-01-2017)
Maxie2U (11-01-2017)
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
All methods of lifting hinder access to some degree. Get a creeper and roll right under. In all honesty, most of the work that can be done underneath a modern vette is either in the front or rear.
jtranger, sorry, I don’t know if it will reach or not. That’s why I asked if you might of had this slick Low Profile/Long Reach jack I linked to.
I looked at when I was shopping, it’s 34 1/2 inches long, so it may do the trick, but I opted out because it’s a heavy booger weighing in at 100 pounds, and bought an aluminum one instead, the one I bought will lift more, weighs less itself, and is more useful for me with my trucks, but won’t do what you’re asking without putting the car up on boards first.
It was an compromise.
If anyone decides to grab it, let us know if it works.
Costco. Got 1 for myself, one for a buddy. 3 Ton, Min height is 3", max lift is 19.75, 26" long. Lower for longer design allows for easy use on cars with rocker trim, even fully lowered on factory bolts. $94.99 at my local Costco.
I also just ordered the 2piece 10" Race Ramps wheel cribs for all 4 corners from Fred at Reverse Logic. I have Race Ramps I use for oil changes and loading/unloading my trailer. Great quality products.
The link you posted is better in every dimension L8ter, and honestly, I was going to buy that one, but I'm just tired of the high failure rate of their products. It's probably just me, but torque wrenches, 4 times exchanged and finally paid restocking fee and returned air compressors and several self distructing rachet straps later, I avoid all their products like the plague. Again, it's probably just bad luck on my part.
On my C6 I used an Omega low profile. Worked great till someone borrowed it and never gave it back.
Get a floor jack crossbeam and you can lift the whole front end or rear end.
I saw a quick jack demo at Carlisle and seems to work good enough, but can't justify the space it takes up for what little I will use it. If I'm going with a lift it will be a post lift so I can park another car under.
