Grand Sport Front Splitter ?
Ok, So I need to get a stage 3 front splitter and stage 3 winglets for my 2017 Grand Sport in Carbon Flash. So my question is who has these things in stock so as I don't have to wait an eternity to receive it after I place the order. Or am I just asking to much of these vendors? I have called around to many vendors and get pretty much the same answer.
Thanks for all your help
Pete
Purple Heart Recipient
Pete
Pete
Pete
I ordered a stage 2 splitter from 2 different vendors. The quality was terrible. I had to send them both back. Guys on this forum were telling me to take a dremel to the splitter to slot the holes because they did not line up. I am going to order from Cultrag or GM. Cultrag has OEM parts. If you want quality take it from my bad experiences, the wait may be longer and the part may cost more but if you want it to look good buy an OEM. The only quality after market splitters that I have seen are carbon fiber...I have a posting with how bad the splitter looks.
No not from C7 Carbon, but again I am not sure of the quality from aftermarket now...I am all done taking chances. If my car was a daily or a beater it would be one thing but being that it is my dream car, I can't stand to have a rough looking piece of fiberglass thrown onto it...
Premium Supporting Vendor
We have in stock so we can ship immediately.
Right now we are running Black Friday on forum at $898/package. Check it out our thread. Here is the link.
https://www.corvetteforum.com/forums...her-parts.html
DWS44 (11-17-2017)
We have exact replica of stage 3 splitter including the winglets and absolutely you WON'T have fitment issue with our parts. Once you install our parts to your car it will look exactly like you get from factory. The color matches perfectly to factory carbon flash.
These are the pictures we have installed on Laguna Blue but no pictures from bottom.
Basically it's EXACTLY the same as GM's parts so it looks EXACTLY the same as what on the car from GM.
Here are the pictures.
I bought the complete Stage 3 kit from Apsis USA and I am completely happy with the product and customer service. The carbon fiber was awesome and the fit perfect. The only thing I didn't use was the hardware and sourced my own. I bought my 17 GS with the poverty splitters and the only thing you have to buy is the air deflector from GM which retails for about $150 or less on eBay. But be forewarned, your front splitter will be much more prone to driveway scrapes and damage. I ended up buying the Protek skid plates and now should I go up or down a driveway and hear a scrape, I don't cringe so much lol. Even on my low profile race ramps (10 degree slope) the front splitter will not clear and I had to buy the extension (6 degree slope). I also wrapped my Aero in Xpel as these CF bits are somewhat fragile. But I have to say, it does look so cool. Good luck.
DWS44 (11-17-2017)
Thanks for sharing the pictures and the thumb up about our products.
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
How hard did you find it to remove the rivets holding on the factory poverty splitter? Did you go back with the same style rivets while installing your Stage 3? I have been considering a Stage 2 splitter and the Apsis sale is pretty tempting, but I've never had a need to remove or install metal rivets before.
DWS44 (11-17-2017)
I am confused about the air deflector. I have installed other stage 2 splitter and had no problems. The splitters I installed did not have an undertray though. Do the air deflectors mount in a different spot. My ZO6 came with the poverty splitter.
larrywalk (11-17-2017)
The splitter is held on by several aluminum rivets and there are some screws as well (see pic). Use a 1/4" drill bit and drill off the heads, and since they are aluminum, they pop off fairly easily. I originally intended to buy the hardware from GM, but they wanted 6 bucks a piece for them and found the same ones, but in silver, from McMaster Carr for 10 bucks for a 50 count box. After you get the new splitter on, and if you had a poverty splitter like I had, you will have to get a new air deflector from GM part #23163400, which you can get off eBay https://www.ebay.com/itm/NEW-GM-FRON...53.m1438.l2649 for under $150. This requires "U" nuts and screws. I used 1/4-20 flat head screws that I found on Amazon that was the perfect size for the countersunk cups on the Protek Skid Plates https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 . The "U" nuts slide onto the splitter and have some play, so the hardest part was getting the entire row of 22 screws to line up correctly, but by using an awls (sharp pointy tool) I was able to easily move the U nuts on the splitter around to line them up with the air deflector holes. Hope this helps and good luck, Allan
Thanks for your help.
Pete
One other question I had...while installing the new splitter, is there any reason you couldn't go back with the regular plastic push-in type rivets in place of the metal ones?
Also note the gap between the air deflector and the splitter on the second pic (not my car) this is caused by a improperly aligned U nut. If you just install the air deflector loosely and start tightening from the center out, you can eliminate these gaps by moving the U nut with a thin phillips screwdriver or awl. Yeah, I know, I have issues
Mick14 (11-19-2017)
First Link https://www.amazon.com/gp/product/B0... ie=UTF8&psc=1
Second Link
https://www.mcmaster.com/#91255a524/=1aax49g
Third Link
Forth Link
https://www.mcmaster.com/#94850a129/=1aax53x
Z06pete (11-18-2017)
BTW, just be careful on jacking up the car and putting it on jack stands. I was uncomfortable with the jack stand locations and even jacking up the car with those teflon pucks tended to make the car squirm around a bit, especially when you are doing both sides. I ended up buying a set of race ramps and then having to buy the extenders as the new splitter required a lower slope to drive on and off. But I love buying car stuff Yeah, it's a sickness.
