Torque converter troubles
My 2016 Z51 lt1 has 7500 miles on it . Over the last month the T C has started acting up ! Yesterday we drove it approximately 100 miles and while on I 20 it started drooping RPM’s and felt like it was skipping . After exiting the expressway it started the shuddering, it felt as if we were running over stop sign warning strips , called my chevy dealer and will take it in Dec. 4 . Service writer said they would change fluid first in trans and see it that fixed the problem . If it still exist they would replace the torque converter . He stated that the fluid change had worked about half the time. My question is with this problem known why hasn’t chevy had a recall on these problems? I love my vette and this is the only problem I have ever had .
They haven't done a recall because for GM it's economics. Cheaper to cover those that fail then replacing every TC out there.
Bingo! Also, it's not a safety issue, and recalls only happen if something is unsafe. I don't think a torque converter problem like this would qualify as a safety issue.
Sucks your going threw the Of the TC.Hang in their.Thought they were Flushing and not just Changing?Tings will be Fine
My brother in law has a 2014 7 speed manual and it has never been in the shop for anything but oil changes ! Guess I guessed wrong with the auto . Kind of reminds me of quality control back in the eighties .
According to a POLL on this forum the majority of TC problems occurred on the 2015's and 2016's. OP, welcome to the club. I had my TC replaced on my 2015 at 10K miles and the transmission has been flawless. I now have 32K miles. Good luck!!!!!
Received 1,738 Likes
St. Jude Donor '15-'16,'18
The TC on my '16 was also replaced at 10K miles. I have 16K now and no problems, so far but I am now using a Range most of the time to avoid V4 mode. Good luck with your repair. Picking the right dealer to perform the work is critical IMHO.
Red C8 of Jax (11-19-2017)
Do I have the right to ask for a new torque converter instead of just flushing it out ? Should I call zone and ask for help on this . Advise please !
Received 2,639 Likes
Plus, I would rather the flush work if it were mine. That way the car won't need to be torn apart. IMHO
tmd937 (11-19-2017)
The following 2 users liked this post by Classic-Chevy-Guy:
Rebel Yell (11-20-2017),
tmd937 (11-19-2017)
Maxie2U (11-20-2017)
Just curious.....With all these T.C. issues, when they get replaced, is it with the same type of unit or a redesigned one? If they are just a replacement unit of essentially the same design, seems like that's a set up for another potential problem. Has GM ever discovered what the problem is, or modified anything in the newer T.C's?
