Corvette Battery Tender
Old 11-19-2017, 11:26 AM
TSLAVette
TSLAVette's Avatar
Default Corvette Battery Tender
Using trunk receptacle, where do u guys run your wires? I ran between decklid and qtr panel - tight fit & don't want to jack up the finish/clearcoat
Ideas or better options?
Old 11-19-2017, 11:38 AM
millpond
millpond's Avatar
No problem doing it this way:
tractman
tractman's Avatar
I use a large microfiber to protect the paint from the wire connection.
Old 11-19-2017, 11:53 AM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,544 Likes on 5,536 Posts
Here's what I do, works for me:
Old 11-19-2017, 12:11 PM
c54u
c54u's Avatar
Yeah, the battery tender wire is quite snug with the hatch closed.
So, I bought at 10ft 12v extender socket and plugged it in the back hatch and led the wire out the passenger window that is a crack open at the top to not pinch the extension wire. I then just plug my battery tender into the extension socket.
Works for me.
TSLAVette (11-19-2017)
Old 11-19-2017, 02:13 PM
TSLAVette
TSLAVette's Avatar
Thanks, Kevin. When I leave my hatch open, the lights stay on ... bought the 12' extension as suggested
Old 11-19-2017, 02:15 PM
TSLAVette
TSLAVette's Avatar
Works for me.
Good plan. Sold! Thanks, c54u (now, C74u!!)
Old 11-19-2017, 02:36 PM
Patman
Patman's Avatar
Received 1,917 Likes on 1,190 Posts
The lights will turn off after about 15 minutes though.
Old 11-19-2017, 02:52 PM
NOMOREWORK
NOMOREWORK's Avatar
St. Jude Donor '13-'14-'15
I did what millpond did.
Old 11-19-2017, 04:07 PM
Frankb10
Frankb10's Avatar
Default Very simple
Hi folks
I am a firm believer on a battery maintainer during the winter.
The GM delco battery on my C6 lasted about 3 years....had trouble finding a new delco battery......wanted to keep it original....invested in a battery tender and 6 years later when I sold it it was still strong...I connected my tender to the terminals with a plug in clip that was provided with the tender..
My C7 has the lighter socket in the trunk that has power all the time...I just plug in the GM tender and run the cable out through the rear of the trunk....no problem..plenty of room for the cable..
Old 11-19-2017, 04:41 PM
2K14C7
Support Corvetteforum!
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I know some don’t believe it but shutting the hatch or trunk on the OEM charger wires won’t pinch or harm the wire or rubber seal.
Old 11-19-2017, 08:30 PM
gpotski
gpotski's Avatar
I just leave the passenger window down 0.25 inch and pass the wire through and plug into the rear socket.
No photo, you'll have to use your imagination.
Old 11-19-2017, 08:35 PM
Avanti
Avanti's Avatar
Received 5,187 Likes on 3,439 Posts
Out the passenger's window, which I leave down for this purpose.
Old 11-19-2017, 09:38 PM
wrecker3
wrecker3's Avatar
Received 1,469 Likes on 741 Posts
I used to leave the rear hatch open until a mouse got in last year. I did not find any damage only 2 acorns so i now close the hatch on the cable and no damage.
To Corvette Battery Tender
Quick Reply: Corvette Battery Tender
