PDR tour mode - anyone recommnend
I will be ordering a 2019 C7 and considering whether to get PDR even though it is unlikely that I will be tracking the car, but I like the idea of having a PDR for the tour mode feature. Grateful if anyone uses PDR for anything other than to track driving performance for the most part. Many Thanks
I've never tracked my C7.... however I use the PDR with every trip.
It's not only fun to play back your rides, especially on winding roads or highways, but it acts as a GO PRO as well.
If you have the Nav, it interacts, such that the actual route comes up on the replay, and with Cosworth software (free download), you can see all of the relevant measurements as well.
Stongly recommended.
Received 2,225 Likes
I'm not tracking my car and use the PDR as a car camera in case of an accident.
Warm regards,
David
I'm not completely sure that keeping a video record of all your activities in the car on a flash drive, in the car is such a good idea.
"yes officer, that is a video of me going 140mph, before I wasn't, and then the idiot hit me..." lol
Yes, I ordered the nav/pdr. I figured it was only money, and I'd rather have it and not use it, than want it and not have it. Besides, I pretty much break the speeding laws every time I drive. (maybe not by much, but they are still broken..) ;-)
Can Vette, can you elaborate a little? I picked up my C7 last month and have not given the PDR much attention yet. I know that I must add an SD card to the slot in the glove box. Does this activate automatic recording of all trips? What about this software you are describing? Is this something you use at home on your PC or a program added to the vehicle? Thanks so much in advance for the clarification and help!
Warm regards,
David
Warm regards,
David
Warm regards,
David
Warm regards,
David
It does not activate automatically. You have to start it from the Infotainment screen when you'd like it to record. Then when you are stopped, you can replay the videos on the screen in the car. Additionally, there are 4 backgrounds you can select from which overlay things like speed, RPM, gear, g force, etc.
I don't use the Cosworth software but I understand you load this on your PC.
Jim
And one of the nice features is that if you forget to turn it on when you start the car, you can activate it while the car is moving.
I have the PDR and use it.
Things to note:
Only records up to 90 minutes or so (due to FAT32 file size limitation)and then stops and you need to start the recording manually again.
The PDR does not tell you that it has stopped recording. You always need to activate the recording manually.....will not start up when car is turned on.
When your sd card is getting close to being full, it does not let you know and the recording just stops recording when sd card is full. It does not automatically delete the oldest file to make room to continue recording. You need to delete a file or files to make room and start the recording again.
32 gig sd card (approx 768 min record time) is max size according to manual. Other have used larger sd card size by using a format utiltiy on their computers.
Pretty sure all the above could easily be addressed by GM with some programming and issuing a software update, but that has not happened.
You can remove the sd card from you glove box and put it directly in your computer and play the videos.
Video quality is just acceptable compared to aftermarket dash cams available.
You can make a shortcut to the PDR software using your favorites buttons.
I still like the PDR but it would be more user friendly if the above were addressed by GM.
Things to note:
It's also a save your a-- tool. Cop was going the other way and made a big U turn. Ran me down about a mile up the road. Asked if he pulled me over for speeding. Told him (nicely) if that was the case he needed to see a video. He looked a little perplexed but went along with me. I replayed my video and it showed him going by me and and low and behold it also showed my speed was 62 mph. Speed limit on the road was 60. He said he was aware of go pros but did not know Corvettes had what I explained to him a PDR built in. Thanked me for the lesson and walked away.
The PDR is really cool for looking over some of your street drives too.
Attached are 4 screen shots from my PDR drives three last weekend and one in July.
The first two are shown using the Cosworth Toolbox, which will get you a look at its date capture, including speed, cornering, track mapping, etc.
The second two are using a computer video viewer.
You can replay on Cosworth, or Windows Media. However, you can also play the PDR videos on VLC player which is a safe free download.
Better yet, I have the VLC app on my IPhone and I download my videos through ITunes from my desktop to my phone.
Not that I would show them off to friends or anything.
Received 1,876 Likes
2020 C8 of the Year Finalist - Unmodified
I have the PDR and use it frequently. I don't track our car.
As others have stated above, I find it a nuisance that you have to activate it EVERY time you restart the car if you remember to do so.....
Other dislike is that it doesn't warn you when you are about to max out the card.
My Street Guardian Dash Cam that I use in our other car has much higher quality video (1080p) and as I leave it plugged in it starts up automatically each time the car starts up. It will also record over itself after the 64Gig card fills up. It doesn't offer any of the "Performance Data" information that the Corvette camera does. It does have a GPS feature that will show your speed, and you can upload the card to your computer to overlay it on a map to show where you drove. The Street Guardian is $200.
I've thought about adding a Street Guardian to the REAR window of the Vette to use as a "cover my butt" for someone not paying attention, or texting that might rear end me. Nearly happened last week, as some dumb *** young girl was texting and almost got me. I looked into my rear view mirror and saw it coming, but luckily she looked up and slammed her brakes on in time.
