Aren't all microfiber towels basically the same?
Received 3,818 Likes
That's like saying all cotton fabric is the same. Waffle weave micro fiber is excellent for drying (if you must use a towel) where other micro fiber towels are better for polishing, but don't pick up water very well. Seen side by side they look and feel much differently.
One more for the Rag Company Korean products.
Bought some specifically for windows and they work like magic.
Doesn't matter what brand window cleaner I've tried over the years.
These towels are what make the difference.
The best one's on the market as far as matching price to quality for waxing and polishing are the Costco yellow towels. They cost about $16 for a 36 pack. I also use these towels for cleaning windows inside and out and they work great. Best of all you dont mind tossing them in the trash when the time comes because of their low price. I use these towels for everything. But when it comes time to dry a car the purple Wal Mart towel that costs me $8 comes out. That thing will suck up water like a vacuum.
I researched this topic a while back and came away with a couple of things that I had been doing wrong.
First, the MF towels should not be dried using high heat. This ruins them. I had always done this.
Second, look at the blend of the towel. Towels that are greater than 80% polyester will scratch the cars surface. Most cheap towels (and all of mine) were higher than 80%.
I order some nice towels from the RagCompany based on recommendations and specs of their towels. I have not used them yet, however.
You can dry them, but don't use fabric softener dryer sheets, which does ruin them.
Wash your microfiber in the washing machine with detergent only. Tumble them dry on low heat or no heat. High heat will literally melt the fibers while fabric softener and bleach will eliminate the electric charge that makes microfiber so effective. Avoid those three laundry habits, and your microfiber will last indefinitely.
walleyejack (12-15-2017)
This is what was recommended by a buddy of mine that details six figure cars daily.
https://www.theragcompany.com/eagle-...rofiber-towel/
You also need a mild detergent to wash. I use this
As mentioned, I tumble dry no heat or very low heat.
The following 3 users liked this post by segen77:
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
Which ones specifically are you using for glass? I have several MFs that I bought (from another source) that were supposed to be good for glass, but every time I've tried to use them, the leave tiny fibers all over the glass. From your comment, I'm assuming you don't have that problem with yours!
Received 5,216 Likes
I bought a large, expensive, car-usage oriented, name-brand towel... and, I hate the thing!
First, it is still shedding its loooong nap after several uses (part of what I thought these things didn't do), it is too large to use effectively when even a little wet--too heavy to manipulate well and thus avoid streaks, cannot be wrung-out like a cotton towel, and probably something else... yeah, takes forever to dry.
I've stuck it in the back of the cabinet, but, I've thought about cutting it into smaller pieces and just using on window, maybe.
NOT better functionality through "hi-tech," imho.*
Also, there is another thread here with more technical data, for example, how to wash, dry, etc.
Which ones specifically are you using for glass? I have several MFs that I bought (from another source) that were supposed to be good for glass, but every time I've tried to use them, they leave tiny fibers all over the glass. From your comment, I'm assuming you don't have that problem with yours!
After I tried them I bought more
The following 3 users liked this post by Dif:
#33
Received 3,439 Likes
DWS44 (12-17-2017)
#34
https://www.amazon.com/Chemical-Guys.../dp/B001TJXWH4
miami993c297 (12-17-2017)
#35
Does anyone here have any experience with MF towels from The Chemical Guys? I ordered a pack along with some wax from them and awaiting delivery tomorrow.TIA
#36
Patman (12-14-2017)
#37
I've always used the Absorber. Last night I washed my C7 (1st time) and dried it using a brand new waffle microfiber (Chemical guys). The microfiber can hold a lot of water. The Absorber can't hold as much. However I find that for me the Absorber is far superior. I can easily wring out the excess water and once the Absorber is damp it sucks up the water much easier than the Microfiber. It seemed the Microfiber didn't want to give up the water that was in it.
In wipe action the Microfiber did a good job of absorbing water, but left a lot that required additional wipes. The Absorber acts more like a combination of a squeegee and the microfiber absorption thus leaves a much dryer surface.
The Absorbers I have are old and that may be part of it (better with age?).
BTW - I'm also a one bucket guy. I use 2-3 microfiber mitts. Do a section with one side, another section with the back, new mitt and repeat until done.
#38
#39
I have an unopened Absorber in my garage!
Maybe it's time to try it out?
#40
St. Jude Donor '11
Chemical Guys and others sell a laundry detergent for microfiber towels. It may be marketing bs, but seems to do a good job.
I find that soaking dirty rags overnight in a bucket with the detergent really helps. Also remember you can't wash microfiber towels with anything else. They pick up lint from cotton, etc.
