HOW TO: Installing JW Motorsports Stage 2 Front Splitter on a C7
No OEM splitter undertray support?
So, I have a question? First I really don't like the idea of drilling a whole bunch of new holes when I can use existing mounting bolts underneath and then drill a lot less. Maybe I am missing something here. Mine came with only a few holes drilled. Does anybody have a trick to find out where to mark the hole locations, the drill and use most of the existing mounting points? Maybe it is easier to just drill new holes.
Also, I see many get damaged and wonder if I need to replace some day how hard is it to get the rivets out? Thanks for any help. my spoiler is sitting on the ground right now in front of the car. I am almost thinking of buying the Z06 grill, remove the bumper and prep the bumper and spoiler with mounting points. Good excuse to the the Z06 grill.
I'm Batman..
Pro Mechanic
Thanks, I see you point! I have a different one that is more competition style, large flat area underneath. Looks some holes and riveting are to be done.
Account disabled by request 1 Mar 2018
Nice write-up FE. Nice add on to. How much total $$$ do you think this add-on would cost for all parts used here? Also, curious about that heat exchanger you have on the bottom tray. That’s not stock OEM for a StingRay is it? What’s that all about?
I'm Batman..
Pro Mechanic
That heat exchanger you see is my blower intercooler.
I am aware of the many excellent tech write-ups that you have done on this forum. Kudos to you. It sure would be a nice to know if you could include some pricing info if possible. I think it would aid in helping members decide the costs associated with the project you are working on and help them budget for thier projects should they decide to do the same as you. Just a suggestion. Keep up the good work. Many appreciate what you are doing.
I'm Batman..
Pro Mechanic
Thanks man, I try! Since these parts are specific to JWM, I know he has posted pricing for the skirts and the splitter in prior posts above. As for things like pricing on the hardware, not much. If you budget $20 on hardware you’d be fine. For the whole job, you can get away with both the sides and the front for less than about $700 I believe in carbon fiber.
#33
craftsmanship?
Curious to know how well are these made and look compared to the more expensive front splitters? They do look good on your car and great write up, thanks. Can you tell the difference between this and the factory stage 2 splitter?
#34
I'm Batman..
Pro Mechanic
Well, I don’t have a factory stage 2 splitter to compare with, but that would not be a fair comparison honestly. You cannot expect an aftermarket part to fit/look like OEM. A fair comparison would be to compare it to other aftermarket vendor options, in which case the craftsmanship is great. I purchase the side skirts and was so impressed for the cost point that I bought the splitter too. I may at some point change it up and swap over to the JWM Z06 style side skirts (purely preference). Either way, you can’t go wrong.
JW Motorsports (02-21-2018)
#35
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
#36
349 for the Stage 2 splitter in CF?
#38
#39
Banned Scam/Spammer
A trick I’ve heard from customers is to apply a small amount of paint to the bolts. Mock up the splitter to the bumper while still wet. They will leave a paint blob where you need to drill. Add a few more self tapping screws for additional support.
MrGary2011 (02-21-2018)
#40
Thank you, I will definitely give that a try
