us 3300 battery charger
Lifetime Supporting Gold
I don’t know if this helps but in my convertible I closed the trunk but did not latch, I’d think you could close it enough to get courtesy lights to turn off but I doubt you can close it all the way
Received 3,818 Likes
This has come up many times here. You can close the lid. It won't hurt the wires.
Received 2,045 Likes
St. Jude Donor '13
Lots of people reporting no problems from this technique. If you want to be conservative, run the thin wires over the weatherstrip in a different location each time.
Since our garage floor is a salty slushy soupy mess all winter, and I don't drive the car during that time, I run the thick extension cord into the trunk and gently lay the trunk lid on the wire. The light times out after a few minutes. It's theoretically possible for rodents to crawl up the wire and get inside your car, but they can do that even with everything closed tight. And I have my own active program to put all rodents in our area on the endangered species list, working well.
