Wheel/tire lift?
Wheel/tire lift?
First off I have a Quick Jack to lift my cars off the ground. As I get older, and with a bad back, removing the wheels is a real pain. Putting them back on is the hardest. Lifting them and getting them lined up with the lugs is difficult for me at times. It seems to me there should be a lift of some kind designed for just this purpose. I have searched the internet and found nothing. Is there a lift or an attachment of some kind for a floor jack that would work, or am I the only one that finds this a problem?
Maxie2U (02-18-2018)
Apocolips (02-18-2018)
A couple of pins with a hollow end that's threaded to screw onto the studs works great and makes it easier.
Maybe that's what I need to try. I have a couple of floor jacks that are just lying around. I'll fabricate a platform/pad that fits the jack and give that a try. Thanks everyone!!!
I don't have a dog in this hunt, but... take a look at this guys video... looks like it could be interesting
https://www.youtube.com/watch?v=fU_M2szF_1E
I use these stud extenders from Reverse Logic.....still need to lift the wheel but by using these extenders its much easier to get the wheel on the studs without damaging the finish on the brake calipers or wheels.
http://www.reverselogic.us/lug-guides.html
[QUOTE=ralston;1596619963]Wow... there's also a product out there... it's $$$ but it exist.
https://store.snapon.com/Hydraulic-W...n-P648811.aspx[/QUOTE
Some cheaper alternatives
https://www.northerntool.com/shop/to...397781_397781?
https://www.tooltopia.com/otc-tools-1769a.aspx?
Maybe a Motorcycle jack could work for you you should be able to set the tire so it rest on both sides of supports and then just jack it to the height you need
Tire Lifting
"Female Threaded Lug Guide Tool" on 01/11/18 and
"Tire Dolly" on 08/16/17
Much good information from members here. Good luck.
Bob
Forgot to add that I am in the same boat, and now use the lug extenders and the wheel dolly on both my C6 & C7.
Try looking at these two threads in C7 General:
Bob
Bob
Received 8,919 Likes
The easiest way to get the wheel onto the hub is to lower the car to the point the wheel will only be 2 or 3 inches above the ground when on the hub. Then lift the wheel and place it on the caliper, squat down and rotate the wheel until the lugs line up and push it on.
Bill
Check out this link:
https://www.corvetteforum.com/forums...on-tool-3.html
See post #44 for a 12" wide wheel dolly. The one from Harbor Freight is only 9" wide.
Apocolips (02-19-2018)
