Smokie tail
Smokie tail
I have a 2018, i bought new.1Lt stingray, with. 2300 miles. Back iin Sept 17, i saw white smoke come out of my exhaust twice on the road. Took it to dealer, could not find reason. This past Saturday, it happenrd again. I look in my mirror and saw white smoke coming from the rear. It happened twice on the road Oil pressure reads 32 psi. Could use some advice
E-Ray, 3LZ, ZER, LIFT
Received 9,623 Likes
Check the oil level just to be sure it is not overfilled. If a dry sump excess can dump into the air intake.
Received 8,928 Likes
Oil smoke is blue, coolant makes white smoke. What were you doing with the throttle when you saw the white smoke.
Bill
Bill
Avanti (03-07-2018)
... or it could be just steam if it’s cold. I’d still get it checked out by the dealership to be safe. As mentioned, burning oil is blue, and coolant is white. The exhaust smells different too.
Some suggestions:
Unburnt fuel – do you smell fuel? – have fuel system checked out.
Coolant leak into engine – check coolant level and pressure test and check for leaky head gasket.
External coolant leak – check coolant level, visually inspect cooling system and pressure test.
Water vapor – water accumulating under car and spilling onto hot exhaust or water splashed up onto hot exhaust and evaporating.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
White is coolant IF there is a coolant leak getting into the engine. Is your coolant level ok?
Elmer
Received 2,639 Likes
My '16 did that once last year. It hasn't done it again, so I'm not to worried. I have no idea why it happened, or if it will happen again. It looked just like steam when a car is first cranked in the cold, and dissipated as quickly.
Please keep us updated as one never knows when they may need the info. Good luck, I hope it's nothing serious on yours.
Rebel Yell (03-17-2018)
Funny, I am also an A8 Arctic White in NW Washington!
The reason i asked is that my car was belching a bit also and it seemed related to the AFM.
Since I put the Range device on, no “smokie tail”.
