Where is your key fob?
#42
Yes, that's certainly possible if it's out of range of the receiver, which it certainly could be buried in a bag in the rear storage area, and if you have the auto lock feature enabled. I don't ever use that because I only want my car locked when I hit the lock button on the fob.
#43
Link?
Do you have a Link? Can't find it-thanks!
#44
Received 3,439 Likes
#46
I keep my fob in my pocket when I'm out of the house, and on the bar that's near the garage/house entrance when I'm home. That way, when I see the fob, it reminds me that I'm not in my Vette, and I'm that much closer to the alcohol to drown my sorrows.
#48
When in use, in my left pocket, iPhone in the right, wallet in hip pocket...made it a habit to do a "3 check" before leaving the house.
When not in use, hanging on one of the hooks I hang other keys on...
Have used the steering column receptacle only to check how it worked.
#50
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
Pants pockets.
#51
Left front pant pocket.
Putting it in the left rather than the right means it's less likely to be activated by seat belt pressure.
#54
#55
I know you can use the cut key to open the trunk, pop the door release, and put the dead fob in the slot to start the car, but I don't know a way of directly using the cut key itself to run the car...
#56
Sorry missed your post. Don't know how to do link. Just went on Ebay type in "5 button fob case holder Corvette caddy srx cts" a few will pop up I got mine from seller nytoptek (2 ) 7.90 shipped .They show none in stock now. There is a lot of other sellers with stock and some with different color cases if interested.
#57
I misspoke. I meant insert the key fob itself into the steering wheel slot.
lavett (04-12-2018)
#59
In pocket to me means inevitably will go through laundry.
Mine lives on a lanyard, and stays around my neck while I'm driving, and "about town".
And case around it is required, as they fall apart and one day you'll find it in half, and will never find the rest of it.
#60
When I returned home I checked the voltage on the 3v battery, which was 3.05v. The replacement showed 3.3v and I had no problems from that point until I bought my 2017. The lesson here is that the fob can get locked in the car despite good technology and intentions, so keep that in mind. It might also be a good lesson to change the fob battery once per year.
SoCalFinest (04-06-2018)
