Old gas
You are fine fill it up and enjoy.
If it was 6 months or more I would start to worry, but 3 months definitely isn't a problem. And even if the gas was a little bit stale, mixing it with a half tank of fresh gas would freshen things up, it's not as if you'd have to drain it out.
I have yet to see any modern fuel-injected engine suffer any gumming or corrosion due just to old gas, nor any failures that could rationally connected to bad gas.
Back in the old days with carbs, sure. Low pressure throttle bodies; maybe. A lot has changed since then, both in fuels and in fuel injection systems.
HTH, and have a good one,
Mike
Mike
That's no problem at all.
Received 2,639 Likes
You're fine. Many have said top it off first but I'd just burn through what you gave and reill at the 1/8th mark or so. Diluting it doesn't help much, might as well get rid of it.
I wouldn't lean on the car very hard and don't run it dry.
