Lloyd Mats - still have green tint? Black vs Ebony?
From what I've read, Lloyd Mats in black and ebony used to have a slight green tint in bright sunlight. However, I haven't seen any recent threads with that complaint. Has that issue been resolved in the past few years?
Also, is the consensus still that the ebony tends to be a closer match to a Corvette's black interior?
Thanks!
Thanks!
I haven't notice any green tints in mine. I bought mine about 2 years ago. When I take it to car shows i leave the hatch open and it still looks good. Ebony is the correct match for the carpets. I'm very happy with it.
I too have noticed the "green tint" to Lloyd's ebony color in the past. I hear that it has been corrected but after people started saying, "why did you order green mats?" when I had my C5 I switched to black in the C6. IMO, black looks much better and not only that it seems to stand out and the logos show better against the darker background.
Ebony definitely best matches OEM carpets. I don't notice any green tint in the below. They are available in the for sale forum, by the way.
Received 2,681 Likes
2018 C5 of Year Finalist
Is the color different depending on which plush level you choose? Ultimat vs. Luxe? I want to match up the OEM 3LZ Black/Adrenaline Red interior carpet and I read earlier the Lloyds black Ultimat is the best color match.
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
TRUTH
Black (Technically Jet Black in Ultimats - Luxe Black is not an oem color match and is a shade or two darker)
Ebony is not even an option for C7
Regards
Chip
MSG C5 (05-06-2018)
The carpets I posted are ebony and that’s what Lloyd’s states most closely matches C7 OEM carpeting.
Simple question I have a 15 3lt and want the best match for my black carpet and I want to get the luxury Lloyd’s floor mats, what color should I order? Thanks chip.
Totally confused! If ebony is not an option for the c7, how come posters above indicate that ebony is the best match?? See post 2 and post 6 earlier in this thread.
the Ultimats. The mats in post number 2 look to be Luxe
Ultimats are a factory matching carpet - C7 is Black (technically Jet Black)
(No Ebony offered) - although we can have them manually made that way
As you can see, ebony is not even an option for factory matching color for a C7 in Ultimats.
Luxe Mats are not factory matching colored mats. NO MATTER what car your drive, even a Prius,
Luxe mats only come in the following colors:
(C6 Carpet is Ebony, so Ebony in Luxe was a perfect match.)
Just about every GM car from 2005 - 2013 with Black Carpet was actually Ebony, which is why it was
one of the base colors for Luxe.
So the answer to your question is, if you want the best match - get the Ultimats.
If you want Luxe - Black will be closest
Regards
Chip
MSG C5 (05-06-2018)
Thank you for the clarification- so it is either a match with the ultimate or a more luxurious carpet with the luxe but a so so match. How much does the match miss with the luxe?
I can't be sure, but the mats in post #3 look to be Luxe Black
Even if they are not, that would be an accurate representation...
Regards
Chip
Received 3,110 Likes
Finalist 2020 C7 of the Year -- Unmodified
I only like GM factory stock or GM factory accessories for mats.
Custom Corvette Accessories (05-06-2018)
