Quick Jack owners, please chime in
Need to lift the car due to back problems and need something portable. Quick jack seems like a good option. Is the jack reasonably light to lift and store with a semi bad back? Will it allow you enough access under the car for fluid changes and exhaust work? Where do you store or hang it when not is use? Thanks
Here is a few picture of my cars at the first and second lift position.
^^^ I agree— a creeper is my next purchase!
FYI — C7 Z51 is about 3400 lbs; C7 Z06 is over 3500 lbs.
Even a 3400 lb car on a 3500 capacity lift is too close for me, but I’m a super cautious guy when it comes to crawling underneath a car, and I like lots of safety margin.
Too many guys get crushed under cars that are not properly lifted. Is it worth the risk?
I have the BL-7000 and also a bad back. But I can still move these around OK and stand them up on the wall (leaning not hanging) for storage. But they are a bit of a load. Just lift with your legs to get the end off the floor. But if I had it to do over again I'd probably go with the 5000 whose units are 20 pounds lighter and still be sufficient to lift my Toyota Tacoma.
BTW, when I lean them on the wall I use a bungee cord across the tops to ensure they don't tip over. The are stable without it but we did have a tiny little (but noticeable) earthquake here some years ago before I had my QuickJack and that might have been enough to get them moving. Better safe than sorry.
I actually hang these on the walls. The SUV comes in with a bunch of snow and salt all winter, so wanted to get these off the ground.
I looked thru Amazon for sturdy angles to use, and came up with these. I use two per lift, and made sure that one went into a stud.
Let me start off by saying I love my quick jack 5000. It makes raising my C6 so easy!! I have had mine for about 2 weeks and my car has been raised and sitting on it for a week and a half. I plan on leaving mine on the garage floor pushed in away from the wheels as they don't recommend you drive over them.
I did notice a few days ago however that my hydraulic reservoir was puckered in. Is this normal when the quick jack is raised?
You have a self-venting valve by the looks of it. Per the user’s manual it needs to be loosened 1/4-1/2 a turn counterclockwise from closed before use, and re tightened for transport/storage to prevent leaking.
That’s the black round fitting on the top of the reservoir you can see in the picture.
h2oskier9864 (05-18-2018)
WOW...Now I know why they state that in the operating manual and post that on the yellow warning label. As the prior member stated, you have to release the breather vent when operating the lift. Be careful when releasing that vent, it appears there is a lot of vacuum in that reservoir to collapse it that much! good luck
#34
They come with a compressor, votlage converter, etc. That's all in the plate box the gentleman above posted a picture of. Everything you need is included, other than the ability to pressurize the cylinders to ~45 psi. If you have a tire inflator that goes up that high you can use one of those for it.
#35
I have the 7000 and it is really stable. I have no concerns about crawling under the car and beating on it while high up in the air - unlike with jack stands. They are just really heavy to move around and lift. They do have wheels on one end. I put those large plastic moving men to make it a bit easier to slide around. I just leave them stored on the floor and park the vette over them.
#36
How often do you guys check your air pressure? I put mine at 50 psi when I assembled the unit last Jan. but not since. Seems to collapse okay now.
#37
Probably fine if they collapse ok in unison. I check mine when they don't. One is always ok. The other was low. So I added some more Teflon wrap on the value on that one. I check them every six months.
#38
^^^ I only use these twice a year or so, so need to check about every time. One side looses pressure in a week or so. Since I have a compressor nearby, it's no big deal to me. Quickjack offered to help troubleshoot, but it adds just a few seconds to air it back up so just living with the very minor inconvenience.
#39
Great post guys..looks like everyone is happy with the jack and it's capabilities
