C7 Engine failure / REBUILD at 4K Miles???
#101
It's a push rod small block V-8; the engine repair should have no impact on value--let them fix the car, pocket the one month's payment and be happy. Or not. But I'd be hard pressed to argue anyone is due more, and I'm a lawyer. My goodness, but you folks are a fussy lot, expecting an engine replacement, or being mad when Chevy wants to fix the motor.
Stuff breaks--that's what the power train warranty is for.
RCraigPorter (05-26-2018)
#102
Almost every day a new bar is set for a sense of entitlement on this forum. OP, while I do wish you luck, you are legally (and that's what really matters) only due what the warranty calls for. Full stop.
And before you ask how would I feel if it were my car. I'd let the warranty fix it and not worry about tomorrow's problems today. Just like I did in 2012 when my Z06 dropped a valve and just like I did in 2008 when my GT500 spun a bearing.
These are very much first world problems. I'd hate to see how some of you guys act when something really serious happens.
#103
The following 2 users liked this post by PatternDayTrader:
Diesel_Jerry (05-27-2018),
#104
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
The following 3 users liked this post by Steve_R:
#105
#106
Received 3,043 Likes
St. Jude Donor '05
is not required to furnish a new engine nor is the consumer entitled to demand it. GM must "repair" the engine and can use "new, remanufactured, or refurbished parts" at their discretion. (Warranty Booklet, page 4.]
#107
entitled: believing oneself to be inherently deserving of privileges or special treatment
I see plenty of it here regarding warranties, minor paint flaws, etc. "BUT ITS NOT PERFECT! I SPENT $80,000 AND HAVE BOUGHT A HUNDRED GM CARS! THIS IS A HALO CAR!" Ad nauseam...
Having to get a repaired (or new) engine at such low mileage is a bummer, but you are NOT ENTITLED TO A BRAND NEW CAR OR BUYBACK just because of it. Period. End of Story.
Things happen. This is exactly what warranties are for.
You say you want GM to do the "right" thing. Well, repairing/replacing the motor IS the "right thing" as spelled out in your warranty.
Then GM went above and beyond "the right thing" by making a payment for you, and extending the warranty -- NEITHER of which they are required to do.
And yet you still are demanding a buyback -- why? Just based on what you feel? If not just 'feelings', please show us all in your warranty (or in any US statute/law) where it says if you have an engine failure in the first x,xxx miles or xx months, you are within your rights to a buyback.
#108
Received 8,928 Likes
I bet these 'replacing the crank; no big deal' that's what warranties are for guys' would be singing a very different song it it were their new C7's engine taken apart with parts laying all over a busy/dirty shop probably being repaired by a tech with limited or no major engine repair experience.
They may only be putting a bottom end kit in the engine. I lost the main bearing on an Olds engine while on a trip. They ordered a bottom end kit and once the parts were in had the car back together in two days.
Putting an engine together doesn't require as much experience as properly setting a diff. However, there are plenty of people that do both themselves at home without all the tools a shop has and don't have any problems. Then you still have the original engine with the proper VIN stamped into it. Why butcher the originality of a car by replacing the engine.
Bill
Foosh (05-26-2018)
#109
The problem here is that dealerships service departments are set up for productivity, hence the flat rate pay scale. This sort of engine repair requires precision, and those two forces don't get along. The probability of this getting effed up is kind of high. I mean who here thinks the tech making this repair is even going to verify the big end of the connecting rod is still round ? I'm betting not one single tech even owns an inside micrometer. No, they will slap it together and hope for the best knowing full well that if it fails again, then they will just fix it again, because its just their job, and not their problem.
Kevin A Jones (05-26-2018),
#110
Complex thinking ... might be over your head.
#111
Kinda bored, Steve R? There is something known as customer satisfaction and working to cement some degree of customer or brand loyalty. Look it up - some call it ‘marketing’. Things do happen in an imperfect world. Companies that take care of those finite number of situations are rewarded. A new engine vs a complete rebuild probably is closer in $ terms than even you might think (see calculator; labor costs; parts; courtesy loaner etc).
#112
It isn't uncommon for high quality machine shops to make grievous errors. It isn't even slightly rare. It seems like 9/10 of every engine that I've "followed" through local machine work, including all the friends I know in a myriad of applications (2jz, sr20, rb25, LS, 4g, 1zz, 3sgt) has come back with ridiculous errors.
Here's an example I found recently
https://www.corvetteforum.com/forums...e-parts-2.html
Just mistake after mistake this guy finds in a "professionally built" engine. Ridges that break off with the force of a fingernail for example. Owning the machine to do the machine work doesn't guarantee the work will be done right.
The following 2 users liked this post by Kingtal0n:
#113
I’ve never felt entitled or thought I deserved special treatment from anyone. I’ve always worked my *** off to get what/where I am today.
However, if purchasing a new car (a fairly expensive one) which includes a factory new engine with an expectation that it’s not going to have to undergo major engine work at less than 5000 miles by someone who may or may not know what they are doing is feeling entitled then I guess that’s me.
IMO, in an unfortunate incident such as this, a warranty should make the owner as whole as possible, regardless what the fine print and legal Es state. And it's doesn't have anything to do 'with buying a Vette' as you say, it has to do with a major automotive company providing good customer service.
Is the opening poster 'entitled' to a new factory engine? Perhaps, perhaps not. However installing a new factory engine in a C7 this new comes much closer to making him 'whole' than making a repair that may or may not be successful.
As I stated early on in this thread, I would push for a buyback without expecting it, but more to strengthen my position to ultimately settle for a new factory engine. Even though not idea as there will be documentation that the C7 doesn't have original engine, it raises the chances that the owner can put this unfortunate incident behind him and move forward without further issues.
#114
Feeling Entitled? Expect special treatment? I assume I’m one of those you are referring too.
Providing and installing a new factory engine in a C7 this new comes much closer to that than making a repair that may or may not be successful.
Steve_R (05-26-2018)
#115
#116
In the corporate worlds where I have lived there has always been a concern in the legal departments of 'setting a precedent'. If GM chooses to go above and beyond their stated warranty for whatever reason, cust service, goodwill, etc, they may be setting themselves up for many more requests for buybacks, upgraded trade values, etc. Word travels quickly about deals being made in the age of the Internet. If I had been the OP I would have handled this on my own / with my attorney without putting GM on the spot of attempting to resolve this problem in public.
I believe this case is simply a warranty matter. If GM would not abide by the warranty then the OP would have a case. Personally I hope the OP gets exactly what he wants and more from GM and the dealerships he is working with - then we will all have ammunition to use against GM if we are not happy with the way our warranty work is handled.
#117
The definition of entitled is "believing oneself to be inherently deserving of privileges or special treatment". If you in fact think you deserve a different treatment than the one you agreed to by contract when you made the purchase and the same one every new Corvette buyer makes...then Steve R would be right and you do exhibit signs of entitlement. Good we got that out of the way by your own words as that was his point to begin with.
Again, no surprise your always taking the dealer's position with your being one or haven been one.
#118
#119
Then by extension, I should have been entitled to a new car because one of the O2 sensors on my car failed at 1K miles. Where does one draw the line? This is not a complete engine rebuild, it's replacement of a couple of components.
After reading through all this, I agree that a buyback is a ridiculous expectation, and a new engine is also unrealistic. An incorrectly installed journal bearing on one cylinder may have damaged (scored or gouged) the crankshaft in that one area only. The rest of the engine is unaffected. Thus replacing the crankshaft and journal bearing is an entirely reasonable approach.
Somehow I doubt the engine is in a thousand pieces. It sounds like a pretty simple bottom end repair/component replacement. There's a lot more complex disassembly required to replace any number of components than this one likely is.
You have a 5y/60K powertrain warranty. If they don't get it right, you'll know soon enough, and then you might well be entitled to a new engine. If it takes them too long in cumulative shop time, or multiple attempts, then you might be able start thinking lemon law, but I doubt that will be the case here.
#120
People retire at all ages, not just at 85 and hope to live just a couple of more years.
I've bought two new Corvettes since I retired(1997 Corvette and 2009 Corvette). Hell, I might even buy one of those new fangled mid engine Corvettes in the next couple of years. Resale value can be very important to a retiree, maybe even more so since most of us retirees are living on a fixed income.
