This sucks
You said some air came out originally, is it still leaking (soapy water check)?
The only thing I'd worry about would be the belts being damaged.
If it's not still leaking you might be OK for a while, and if you DO plug it, that might be the proverbial straw that breaks the belt's back, so to speak.
Tough call based on that.
You realize that if you follow the tire manufacturers exact directions for this repair, then you would install a plug, cut it off inside, buff the plug and liner, then glue a patch in place. Alternatively, you can use a one piece patch/plug product, and ram the plug through from the inside and glue the patch in place. Either way you are putting a plug in the tire. There is no way to handle this repair without forcing a plug through the tire.
What does this mean ?
I have professionally repaired tires in that exact manner.
However, the reaming action might cause the belts to be additionally impaired, resulting in the same type of tire failure I experienced.
And that is why many tire manufacturers recommend AGAINST repairing speed-rated tires.
Again, food for thought.
Everyone is entitled to do whatever they want.
Of course.
on the way to plant tour last year i picked up nail in rear tire closer to the edge. at the time was 35 miles out in the corn fields which were close to nothing. sunday afternoon in Ok. with 9 am plant tour on tuesday. drove about 50 miles with no pressure to find an autozone. purchased plug kit and compressor , made repair in parking lot. made it to bowling green, had great time at plant and on the ride back to tucson. several auto-x later and plug started leaking. removed tire at friends house and patched tire on inside. still running that tire, has about 9k miles on it now.
your tire can easily be repaired. just need to find someone willing and capable.
I don't agree with that at all but whatever I guess. The reaming out of the hole sizes it to fit the plug and exposes the steel cords inside the hole so they grab the plug, which combined with the glue is the reason the plug wont come out. Is it as good as a new tire ? Of course not. Would a serious racer hit the track with a repaired tire ? I wouldn't. Is it safe to fix a tire on a street car ? Hell yes it is.
It ain't cheap!
As I said, food for thought, based on my experience with almost the exact same type of puncture.
Received 2,047 Likes
St. Jude Donor '13
The general experience seems to be that driving more than about 25 miles with no air will usually damage the tire, visible only by removing from wheel and inspecting inside.
I had to drive a PS2 runflat for about 25 miles with no air, the outside looked ok but the inside was starting to "crumble". Since the problem was a sidewall cut that couldn't be repaired, the tire was toast anyway but I would have replaced it regardless.
Using a plug instead of the internal patch-plug repair is also non-approved by most (all?) tire companies.
Continuing to use the tire for long distances and autocrosses ups the odds of problems even more.
I'm glad it worked out for you.
Other people have done similar things and experienced no problems.
My mother smoked a pack a day for her entire adult life and experienced no problems.
But I don't smoke and I don't do unapproved repairs on abused tires.
Fix it today. Replace those worn tires next month or two. They are worn at 6k obvious hard miles from your picture.
If it’s not leaking, file or grind it down and leave it in tire.
Plug, not! A reputable shop will only do patches.
https://www.corvetteforum.com/forums...f-z51-pss.html
#33
Received 5,202 Likes
Compared to the diameter of nails I have gotten (and plugged successfully), THAT is not small, imho. Your car, your damage if it comes apart. All the best, no matter.
#35
I was seriously JINXED by this post. No Lie... I first read it this morning... commented to myself... "I've been so lucky not to have picked-up a nail or screw for SO LONG!" --- Fast-Forward to this afternoon, driving back to the office from lunch, windows down, hearing "click-click-click", check pressure sensor display and sure enough... rear passenger tire down several pounds.
I didn't take a pic of the screw, but it was seriously identical to the one in this original post, just a little newer and shinier. I was concerned about the location, but thankfully, the guys at the shop were willing to plug it right up, and I was out of there in about 20 minutes!
For tire plugging/repair reference, here's an "After" pic of the repair. --- Have a great Memorial Day weekend, everyone!
#36
Received 3,096 Likes
Finalist 2020 C7 of the Year -- Unmodified
#37
NostraD (05-26-2018)
#39
Of course.
So, the tire may fail again? Net Zero to not fixing.
Many manufacturers claim that one fix is just peachy.
Ain't America Grand!
