2014 C7 Z51 launch control rom? Mine is 5100
Thought it was supposed to settle at 4K? Mine is 5K. Haven't drag raced in forever. Tried it a few times and it always is 5K. Doesn't hit he limiter.
Read one post that said it's 3800-5000 depending on temp and tire temp. It was 100 today.
Tested launch control a few times and it stabilizes at 5100 each time. Don't like it as the car bogs bad.
Had better results doing it the old fashioned way.
First I have heard of settling at that high an rpm definitely seems too high for a good launch. I would definitely think you would be better off not using launch control at 5100 rpms.
Will engage it when colder and see if it does a lower rpm. Had car in comp mode via track mode then 2 taps. Fast application of gas with wheel straight. Rpms jump and settle at 5100 steady every time today.
Only used it one time, tested a bunch to see what rpm it would settle at and always 5100.
Please go over activation again?
