How do you follow your build order?
How do I follow build order WFWSGJ?
Sorry for not spending too much time searching for this first, but I have a 2019 Z06 on order and looking to follow the build process if possible. Any suggestions for how to do so?
Thanks,
Zach
Thanks,
Zach
Zach, you have three options, all work, depending on how fast you want your response.
#1. you can call GM Customer Service, follow the prompts till you get to talk to a REAL person and they can/will go into the database and tell you the status. 800-222-1020 its available 8 am-9 pm EST Monday thru Friday.
#2. Call you salesman/dealer....if you have a good one, he has access to the exact same database as the GM Customer Service folk and can give you an update of the status right then and there. My salesman, knowing I wanted to know the status as soon as each status change, he would check every few days and would call me every time it changed.
#3. go to the tracking thread at the top of this section and post your order number and the GM customer Service person here will get back to you in a few days.
That's a good response.
I got lucky, the guy I ordered my C7 from checked the work bench system daily and provided his customers updates proactively.
Thanks for the suggestions. I updated the title to see if anyone is able to track it down. I'll also check with the dealer every now and then, just wondering if there was a way to check in daily to see where it is.
