Yep. Normal. When the engine gets to a certain threshold where it sorta gets in that lugging range, the compressor will drop offline too remove engine drag
Normal - Protection to keep engine running without lugging or dying...
Since idle is 600-700 RPM, unsure how it would see 500 RPM unless driving out of normal RPM range..
My AC compressor turns off if my RPMs drop below 500. Is this normal for the C7 M7?
First I have heard of that happening! But if I were the engine sure would want them to remove that ~3 hp and shut off the alternator as well! If not I'd show you and stall!
