What is that structure underneath my car?
5th Gear
For the past couple of days, I had noticed a noise and sensation that my car was dragging something underneath it while driving at low speeds (< 10 mph) and which was not noticeable at speeds >10 mph. So, I finally took a look under my car and saw this - picture attached. Any idea what structure that is? Thank you!
You are dragging something probably the center section of the air deflector.
Satriani (06-28-2018)
Received 1,762 Likes
ttt
GM new air dam to make r let your car fly. Looks like you didnt get the bolt back in good when you chged out you front grill. Robert
It’s part of the undercarriage air deflector. Looks like the rearward fasteners are missing. Did you have your car serviced recently... maybe an oil change, or whatever? If so, then perhaps the tech forgot to refasten it. Here’s a pic to better illustrate the piece.
Received 5,204 Likes
"... For the past couple of days..."
Let me get this straight.... you had something audibly dragging for a "couple days" and waited that long to check it?!?
The following 4 users liked this post by Avanti:
Received 3,818 Likes
Happened to me last week. It's the rubber air dam that frequently scrapes on driveways or speed bumps which has torn loose from its moorings. IT'S NOT AS IF YOU CAN HEAR IT OR SEE IT. You're driving the car, not peering beneath it. I was with a group of other vettes whose drivers told me what they could see. I cut the piece off very easily with a sharp knife. Consensus on this forum after my inquiry was that it isn't a big deal and need not be replaced.
https://www.corvetteforum.com/forums...ous-or-no.html
5th Gear
It was exactly that. It was partially torn and I'm getting it replaced. Thank you very much.
LOL - I was thinking the same thing. My *** would have had the car pulled over ASAP and looking under it to see what in the hell is going on.
Satriani (06-30-2018)
mschuyler (06-30-2018)
5th Gear
As I stated above, you wouldn't even know unless someone else told you. The sound it makes is not loud enough for you to hear when inside the car. You can't see it unless you peer underneath the car. Even after I was told "something is dragging beneath your car" I STILL could not hear it or detect it in any way. Unless you are blessed with Super Hearing, you wouldn't either. It didn't hurt a thing for me to wait until I got stopped at a safe place so I could cut it off.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
