Corvette C7 acceleration underwhelming?
I have a sbc that makes well over 550chp and with 4.11s feels violent...with even a 3.08 gear it would feel like a pig.
So to have a car that idles like a kitten make 500hp get over 25mpg and run a 12, no it wont feel violent but will still be fast.
Remember when the C5 came out, I test drove a vert 6 spd and thought, "how slow" but reached 100 pretty quick. Same thing
Tall gear, flat torque curve
If the OP drove a GS/Z51 M7 with it's 3.42 rear gear and it's 2.97:1 1st gear he has a total of 10.16 torque multiplication.
Now compared to the Z06 A8 with it's 2.41 rear gear and it's 4.56 1st gear for a 10.99:1 torque multiplication.
Or the Z06 with the M7 with it's with it's 3.42 rear gear and it's 2.29 1st gear, for a 7.83:1 torque multiplication.
Sure looks like a C7 GS/Z51/Z06 A8 has better gearing with it's "lackluster" 2.xx(AKA 2.73:1 or 2.41:1) rear gear vs the M7 with it's "aggressive" 3.42 rear end gears. Don't you think so?
There is more to the story than just the rear axle ratio.
I've stated this before, I had a 4th generation Camaro that started as an autocross car, and then I built a motor for it. Little over 500 HP at the crank, super stiff suspension, loud exhaust, rattles, etc. With the street tires on it, it did the 1/4 in almost exactly the same time as my Corvette. Yet every single person who had been in both was certain the Camaro was much faster. It wasn't, but the drama and noise made it feel faster.
If you want speed, find a car that does it smoothly, and the Corvette will fit the bill. If you want the feeling of speed, you might want to look elsewhere.
As far as "winding country roads" mentioned in the OP, get a Grand Sport and forget everything else. I love the Camaros, the Z06, who wouldn't love a ZR1, but for driving dynamics where power is less important, a Grand Sport is really hard to beat.
IMO...Vettes are not known to be great drag cars out-of-the-box.However,on the track,they shine.
\db2
Anyway, I was just saying that it's all making sense now. The Corvette is not really a light car. If all you are making is around 400HP, that is only 100HP more than many of the lower end cars I've driven which are usually around 300HP but weigh 2800-3200 LBs. The next factor I missed was power band. I needed to consider WHERE the 400HP was being delivered.
As for C7 being fast. I have no doubts there but I'm very obsessed with the visceral nature of performance cars. I'd rather be the slowest guy at each car meet, if my car is the most fun to drive at every meet. For me cars are very personal. It's about what brings ME joy, which is the FEELING I get and the emotion I get from driving. So my focus is on driving dynamics that bring me joy:
Being pressed hard into the seat as I accelerate
Being pressed hard to the side as I do a high G turn
Being able to feel like the car will go wherever I want it; decreasing radius turn? BRING IT ON!
Controlled chaos might be the word some would use for this. See, I have no interest in old school muscle cars that are visceral for sure but make you feel like you are about to die. I may feel like I COULD die if I ever disrespect the car, but I should feel confident that as long as I'm alert and engaged, I'll be OK. Kind of like jogging by the edge of a cliff. Stop paying attention and you could go over but pay attention and you are fine...even if you stumble...however...you STILL are near a cliff so, you can never really fully relax. Old muscle cars to me could be like running by the edge. Any second you could fall and be done with.
I just acquired my 2017 Z51 coupe after owning 2 C6’s including an LS7 convertible and most recently a 2015 Camaro Z28. I can relate somewhat to your feeling as I was somewhat surprised that the C7 did not feel as visceral as the Z28 which I tracked. However I agree with z28lt1 that some of that is due to the refinement of the C7. It is a very fast car it is just much more civilized than some other performance cars. I can’t wait to get mine broken in and on the track I think it is going to shine there.
Even the base can break traction going into 4th.
Now some context. My experience is somewhat limited. Most of my experience with high performance vehicles is on the extreme side; Gallardo, Murcielago, 458 Ferrari, V10 M5, Replica Cobra with Roush 500HP engines, or on the lower side like 320HP NA flat 6 Porche, 300 HP G35, Base model Camaro from 2016.. So I don't know what a "heavy" 500HP RWD sport car is supposed to feel like. Never driven a comparable Mustang or Audi or anything between 3200 and 3500 LBs with near 500HP. So are you surprised that I was underwhelmed? Maybe I need to look up power to weight on all these cars and see where the C7 stacks up?
Also, forget about power. If I want the most nimble and fast Chevy for really technical tracks. A car that does the best for a bunch of fast and tight turns (not sweepers but winding country roads that might make many drivers nervous without the right cars). Which is the one to get? C7 or Camaro ZL1? Let's say you were going to be forced to race at incredible speeds around a winding mountain road were if you slide of the road you will fall thousands of feet to your death....which car would you drive? Stock Z06 or Stock ZL1? How about if you were going to drive at safer speeds but would have your girlfriend in the car who would dump you if you scare her too much...which would you drive? This means...which care FEELS the most stable in sharp fast turns even if it's not necessarily ACTUALLY more stable? Just because a car maybe giving you a LOT of feedback that your mind takes as instability, that does not mean the traction levels are any less. What you FEEL is not a scientific measure of traction levels. So:
Which one has traction and stability levels that are like being on rails?
Which one FEELS like it's on rails even if it's not?
Thanks in advance!
BTW...as if this was not tough enough already...I just checked out the ZR1....damn!! I feel like I need them both!
Also, if I was to create a dream car, it would be based on a Lotus car as for handling, but pull to 60MPH in 3 seconds or less, be obnoxiously loud WHEN you beat on it, but reasonable at idle, have a reasonable street mode that feels OK for comfort, but driven hard in a "track mode" would give a lot of feedback and be very viceral (push you back in seat, aggressive gear shifts), put a smile on your face just cruising town. Priorities are in order: HANDLING (on rails, precise), HARD acceleration, loud (sounds angry).
