My Corvette Warm Up Procedure
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
I have my own ritual I'll describe below, but I was wondering how many of you Corvette owners have your own ways of giving your Corvette a little TLC. I realize today's Corvettes need to be thoroughly warmed up before going WOT and so before I pull out of my garage, I make sure she's fully warmed up so I can get on that gas pedal as soon as I hit the street. She's a screamer and does not like to wait until several miles down the road to let loose.
Before I get in, I walk around back and unplug in my Corvette Battery-Tender in the rear outlet and close down the hatch. I then walk to the front, close the hood and place my forced air kerosene heater (pictured below) in front of the car blowing at maximum high fan-speed/high heat setting towards the inlet openings and the front of the car.** The heated air blows around the engine and also down under the chassis exiting from the rear of the car and out from the garage. I then go in the house and grab my morning coffee. About 15 to 20 minutes later I go back out and walk around behind the car. By this time the air I feel exiting from behind the car is now hot, no longer the cold rush of air I felt earlier when I first started. I figure this performs a couple of important things.
First it warms up the engine by blowing heat through the radiator, sure the fan and water pump aren't operating, but the gradually warmer fluid in the radiator sets off a natural circulation of the fluid adding some heat to the block & heads. Second by blowing hot air around the engine, I warm up all that cold air which was freezing those plastic engine and trim pieces that live under your Corvette's hood.
I believe that over time, this process along with wiping the hoses and plastic fitting with protectants will greatly add to the longevity of the engine and hoses and the under-hood youthful look will be retained much longer.
So who else has the **** tendencies........lol
** "Your Results May Vary. Past Results Do Not Guarantee Future Success." Use At Your Own Risk."
The following 11 users liked this post by ExRedRacer:
dmaxx3500 (07-04-2018),
ErikR (07-07-2018),
LbulletM (07-03-2018),
Null Pointer (07-02-2018),
ON RAMP SLAYER (07-02-2018),
and 6 others liked this post.
Popular Reply
07-02-2018, 09:57 PM
Received 5,202 Likes
I push the "start" button and drive away, the same as I do with all my other street vehicles.
The following 2 users liked this post by Jeff V.:
madrob2020 (07-02-2018),
SRQStingray (07-03-2018)
The following 12 users liked this post by Avanti:
4thC4at60 (07-03-2018),
blkvet6 (07-03-2018),
davefreeman (07-06-2018),
Dcregar (07-04-2018),
and 7 others liked this post.
Is it April 1st because this has to be a joke.
vbdenny (07-04-2018)
Zaphod B (07-04-2018)
A totally unecessary, and silly practice. Whatever........
Maxie2U (07-02-2018)
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
Thread callback perfection. Well done!
Even serious sub-forums need a little comic relief once in a while. up, Ex Red!
The guys in off topic refer to this as a parrot thread, well done OP, well done
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Had to know this was coming.
I’m still wondering if the other thread was real or a troll. I hope it’s the latter or the dude has serious mental issues.
In the immortal words of Charlie Brown - "Good grief!"
The following 5 users liked this post by SilverGhost:
Billy346 (07-03-2018),
JamieJT (07-05-2018),
Mike Campbell (07-04-2018),
mjdart (07-03-2018),
Rocky51 (07-03-2018)
Is this the same guy that puts a big shop fan in front to cool it down? Dude! It's a CAR... It isn't a F1 engine where it won't even turn over unless the oil, and block are 180F.
