Oil Change...need some help
Old 07-05-2018, 05:37 PM
jimmbbo
jimmbbo's Avatar
Originally Posted by DWS44
Thanks for the suggestion, but yeah...my sockets won't fit into that small space, and when I switched to the 6-point wrench, the rounding continued...that's when I stopped.
A box end wrench will fit and provide the security of a socket.
DWS44 (07-05-2018)
Old 07-05-2018, 05:42 PM
Skid Row Joe
Skid Row Joe's Avatar
Received 4,000 Likes on 2,887 Posts
Success! Death-grip vice grips and a BFH won the prize.
Thanks to all who chimed in! Now off to get a new drain plug and get on with my vacation to-do list.
Is/was there a crush ring copper washer under the bolt head? One tip that may help in similar situations is to lightly heat up the bolt with a blow torch with a few passes. Heating makes them turn loose as well.
DWS44 (07-05-2018)
Old 07-05-2018, 06:35 PM
DWS44
DWS44's Avatar
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
No, it was just the OE rubber gasket once I got it off. I used to always use copper crush washers on my 370Zs, since they were the Nissan OE solution.
Skid Row Joe (07-05-2018)
Old 07-05-2018, 06:51 PM
vbdenny
vbdenny's Avatar
You just learned a valuable life lesson just the way I did a long time ago. Six points for you.
Old 07-05-2018, 09:32 PM
FunDriver
FunDriver's Avatar
Smiles. Now you can go about doing it right.
DWS44 (07-07-2018)
Old 07-05-2018, 10:31 PM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,685 Likes on 5,589 Posts
This style ratchet wrench works well for C7 plug removal without damaging the bolt head.
DWS44 (07-06-2018)
Quick Reply: Oil Change...need some help
