Parade Question
Old 07-06-2018, 11:48 AM
Dyn
Dyn's Avatar
Default Parade Question
So, it has been suggested I use my convertible in a parade and park a 120 pound model on the tonneau cover. Can the cover handle her skinny butt, or will this break something?
Old 07-06-2018, 11:53 AM
joemessman
joemessman's Avatar
Received 3,436 Likes on 2,057 Posts
You'll be fine, but it would be better if she had a more full figured but.
Old 07-06-2018, 11:54 AM
SoFloVette
SoFloVette's Avatar
Need pics of the model for a full evaluation and potential damage report
Bigfoot16 (07-08-2018)
Italianfox
Italianfox's Avatar
Anyone know what the weight limit is?
Old 07-06-2018, 12:40 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
It depends on what she's wearing and clear your rear view mirror is.
speed4tu (07-06-2018)
Old 07-06-2018, 12:50 PM
RyanC7
RyanC7's Avatar
Old 07-06-2018, 12:53 PM
mschuyler
mschuyler's Avatar
Received 3,818 Likes on 1,614 Posts
Long dresses would add significantly to the weight. Best to wear a bikini to keep the weight down.
Old 07-06-2018, 01:00 PM
theplatinumog
theplatinumog's Avatar
C7 of Year Finalist (track prepared) 2019
damn, my model was < 100lbs... BE CAREFUL!
Old 07-06-2018, 01:23 PM
wyefox
wyefox's Avatar
Old 07-06-2018, 01:31 PM
Avanti
Avanti's Avatar
Received 5,187 Likes on 3,439 Posts
Nothing to see here. Let's move along.
Old 07-06-2018, 01:35 PM
rogergcam
rogergcam's Avatar
Default model
She will likely break your heart!
Old 07-06-2018, 01:43 PM
ImpliedConsent
ImpliedConsent's Avatar
Originally Posted by wyefox
FINALLY a great use for that emoji.
Old 07-06-2018, 01:46 PM
DWS44
DWS44's Avatar
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
Nothing to see here...yet.
Old 07-06-2018, 01:54 PM
JJAY
Support Corvetteforum!
JJAY's Avatar
It's better if you can distribute the weight ...
Old 07-06-2018, 01:55 PM
Dcregar
Dcregar's Avatar
Originally Posted by RyanC7
Old 07-06-2018, 02:01 PM
Mayor111
Mayor111's Avatar
Received 1,945 Likes on 934 Posts
Tell her your car is made of fiberglass, and to avoid any "fiber-rash", she should sit in your lap while you drive...that will make everyone happy...
Old 07-06-2018, 03:48 PM
theplatinumog
Bleh. If I were on a computer Inwould post from "my bitch" album here on cf
To Parade Question
Old 07-06-2018, 04:05 PM
joemessman
joemessman's Avatar
Can I drive?
Old 07-06-2018, 04:58 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
The cover can handle the weight. There are three problems: Two are safety issues. 1). Models usually wear some sort of clothing that slides easily against solid waxed surfaces. The first thing you need to do is to make sure it is less likely to fall off the car and get injured. I found buying a cheap non slip bathroom carpet at a local superstore will provide enough grip to keep her on the car while protecting the finish at the same time. 2). The second problem is making sure she doesn't twist an ankle trying to stand on the seat while getting into position. 3). The third problem is a variation of the second one and relates to protecting your car seat. The models will typically be wearing high heel shoes so you want to make sure they remove them as the step into the car and before they step on the seat. The next thing you need is to provide a hard surface for them to stand on instead of the seat cushion. I found a section of board cut to fit between the edges of the seat cushion distributes the weight better and provides a little more stability for somebody to stand on the seat and turn around to sit on the tonneau cover. I made mine from a piece of 2x8 wrapped in heavy duty paper. I found this stuff out when I participated in my first high school home coming parade with young girls sitting on the tonneau or on the roof halo of a T Type car. I had taken care of the seat issue so she got up on the roof halo followed by her date placing the board on the floor and sitting in the seat. Then I let the clutch out and as soon as the car started moving she started sliding across the halo. I had her date grab her legs and hold her in place until we finished driving the quarter mile into the football stadium where they got out of the car. Even going around a turn at 3 or 4 mph generated enough G force to make her slide. From then on my standard parade issue was the carpet and the board.
Bill
The following 3 users liked this post by Bill Dearborn:
Dyn (07-06-2018), Rebel Yell (07-07-2018), SilverGhost (07-07-2018)
Old 07-06-2018, 05:08 PM
mschuyler
mschuyler's Avatar
Bill's reply reminds me of the following:
Two engineers were talking. One engineer said to the other, "Where did you get that bicycle?" The other engineer replied, "Well, I was walking in the park and this young woman pedals up on this bike, throws off all her clothes, and says, "Take what you want!" The first engineer says, "Good choice! The clothes probably wouldn't have fit you anyway."
joemessman (07-06-2018)
Quick Reply: Parade Question
