Low Fuel warning - "A man's got to know his limitations"
07-10-2018, 10:04 PM
Disregard... posted in ignorance...
07-10-2018, 10:21 PM
Quote:
Originally Posted by
Tom760
Not sure if this was a typo...
C7 Corvette Fuel Tank Capacity is 18.5 gal...
Doh... There it is, page 321 of the manual... 18.6 gallons... Unsure where I got stuck on 16 gallons, but been using it for months... Thanks
07-11-2018, 03:10 PM
~16 gallons is my normal fill-up. Probably where it came from.
07-11-2018, 05:21 PM
LbulletM
When I was researching the car, I think I read/heard/saw 16 gallons, which stuck as it was the same as my '11 Mustang...
07-11-2018, 06:29 PM
Never let mine get below 1/2 tank You never know when your going to need extra fuel for those power pushes
07-12-2018, 03:23 AM
ChuckerC7
That's my SOP as well, but I am more comfortable if I know where the edges are...
07-12-2018, 06:15 AM
St. Jude Donor '20-'21-'22-'23
ChuckerC7
Too much extra weight, need to be lean and mean for those unexpected races!
The following 2 users liked this post by HorsePower Junkie:
07-12-2018, 07:00 AM
As far as i am concerned the best dirty harry line
07-13-2018, 05:18 PM
slant6
a man has to know limitations, comes from “Cool Hand Luke” not Dirty Harry
07-13-2018, 05:42 PM
HorsePower Junkie
I find the opposite with the OEM tires on the street, with the tank closer to empty I get a lot more wheelspin off the line compared to when I have a full tank.
dprestidge
Magnum Force
The following 2 users liked this post by jimmbbo:
07-13-2018, 06:01 PM
dprestidge
Bzzt! Thanks for playing! What you are probably thinking of is "What we got here is a failure to communicate."
07-13-2018, 07:24 PM
It was my understanding to not let the fuel level routinely get below a 1/4 tank since the gas cools the fuel pump
07-13-2018, 07:42 PM
HorsePower Junkie
When it's full, that 's about 100 pounds.
Dave
07-13-2018, 07:54 PM
dprestidge
07-14-2018, 07:00 AM
Best line from cool hand luke, Calling it your job dont make it right
07-14-2018, 09:33 PM
St. Jude Donor '13
Jmhornz71
Old aviation saying:
"The only time I have too much fuel is if I'm on fire."
I normally refill at the first convenient time below 1/2 tank, but over the years in different Corvettes (including our 2017) I've run down to "Low Fuel" a fair number of times, that happens when the gauge is slightly above Empty.
Others have posted that the pump is cooled by fuel going
through it, not pooled around it. You're ok unless you run completely empty, then the pump burns out quickly.
But I can't prove or disprove either theory. Anyone know for sure?
07-14-2018, 10:25 PM
If weight were a genuine issue, most Vette drivers I've seen would be far better off, in more ways than one, losing a few pounds themselves.
07-14-2018, 11:02 PM
Avanti
