A8 Tranny - Have they fixed it?
#62
Common sense dictates that everyone has the same A8 with exact same parts. Failure rate is high so weather 10 miles or 50.000 chances of everyone with the A8 to have Torque converter problem at some point is very high.
#63
I've decided to be proactive and get the triple flush done asap. My '17 GS only has 2200 miles on it and no problems yet (though I've only had it a week and a half) , but knowing the issues, I'll just feel better taking that initial step to protect the tranny.
#64
#65
Cruising
2016 Stingray A8 Studder
I started noticing the "studdering" about 3 weeks ago on my 2016 Stingray with A8 with about 22,500 miles so I came for an answer on the forum. It is an early 2016 modeI. I will be heading to dealer this week. I haven't read all the posts but it looks like the TC is the major problem. Any suggestions on how to approach dealer. I don't think we have a dealer in the Jacksonville,Fl area who knows how to repair Vettes. Just sell them.
#66
The drive lines are being destroyed by AFM. You would be seeing similar issues in the M7 cars if they kicked into AFM in all modes like it does with the A8 cars.
When AFM puts your car in V4 mode, it is damaging the driveline - the GM engineers saw this issue when developing these cars which is why they changed the driveline to steel vs aluminum in an attempt to reduce the damaging vibrations caused by AFM and V4 mode. Obviously, they underestimated the amount of vibration caused by V4 mode in terms of the stress it would put on all the other driveline parts (like the squashed torque converter...).
I agree with your point about the class action lawsuit, this is a completely unacceptable situation. The worst part is that this is a design issue and GM is just bandaging the issue by replacing the parts that fail without addressing the core cause of the issue, meaning that the parts will continue to fail, even after everyones warranty is expired, leaving the owners of these cars with faulty drivelines that will continually fail over very short periods.
#68
Dodge had timing chain issues with their R/T cars from AFM.
They made a design change after YEARS of failures.
Nissan in their 370z MANUAL cars, has faulty clutch master slave cylinders, but after YEARS of failures, like GM, is doing nothing but replacing, when failure occurs.
So my question is, these design engineers, what is their exact job?
Do they not address faults because it makes them look bad because their initial design or concept was flawed?
Certainly seems so!
911Hunter (08-20-2018)
#70
GM changed the fluid... new fluid from mod 17 forward is a low friction type. The bottles have even changed to reflect it.
saw it at the dealer when I was picking up my car after oil change. Chatted with their Corvette tech who used to work for ECS and is the only tech I let touch my car.
he had an 8 speed apart and we spoke about it.
Jeff Strausser from GM Corvette division. Told us this face to face last year at Carlisle. Amid it's common for mfrs to make changes to viscosity over course of lifespan etc.
That guy is the man. Handed out his cellphone number to all of us. And we have chatted a bunch. He had the plant send me the new designed Z06 vents before they were even out to expedite my paint issues. So i took hin at his word and the texh i mentioned before corroborated it. So any mid year 17 has it and all forward. Tech said if you have the issue its triple flush and afterwards a TC change if it doesn't fix it. But will be fine either way its addressed.
767guy (08-20-2018)
#71
#73
#75
