HELP! New apartment, center of car SCRAPES a LOT
Hey guys, I have a bit of an urgent problem. I just drove from Philly to Santa Monica for work for 1 year. The garage in the building has an absurdly steep valley on the way in and a steep decline down the driveway after -- such that I can avoid scraping the nose of my car if I come in on an angle, but the center of the car scrapes badly on the way in. There is a guy with a freaking McLaren in the garage and it's actually higher than my car, but also scrapes. I think (hope) it's just the aftermarket side skirts that I put on it, because I couldn't see any significant damage when I looked underneath with a flashlight, but I need a solution ASAP.
Back in Philly, we used some ghetto planks of wood if need be. They seem open here to a solution, but at least in the meantime, I hope to buy something I can put in the trunk of my car to help me get in and out. Ideally, something I can get on Amazon with 2 day or overnight shipping. I need some sort of ramp that can fit in the car -- ideally something that I can fit well into the valley to prevent the dip. Something 5 inches high or so at least, I think would be safest. Anyone have any suggestions?
A much less important question also: anyone have any recommendations for hand car wash locations near Santa Monica? I always hand washed the car myself, but that's not allowed here. Thanks!
Use a2”x10”, cut to length you need. If need be, screw 2 together to make it 4”x10”. Mitre the edges 30 degrees.
Another option, for the next year at least, use the factory bolts to raise your suspension all the way. Lower back to normal when you get back to Philly
SilverGhost (07-24-2018)
Thanks guys. How much higher can I get it with factory bolts? This sucks so much. I bought a rocker grate I thought would help
today, but I need a much longer level. See photo.
That curb gonna eat your side skirts.
1. Bolt how to thread, how much? probably an inch raised
lowering on stock bolts how to
2. Move, that's what temporary apartments are all about.
LT4CMG (07-24-2018)
SilverGhost is pretty close I think. I dropped mine last yr from the factory settings all the way. The front ended up settling about an inch lower, the rear about 7/8. Factory bolts are roughly at middle point. So maybe you’ll gain 3/4 to inch?
Received 5,216 Likes
That looks terrible! From the pix I cannot believe only the skirts are dragging... if so, though, you best leave them to it until you work out a temp solution. I agree; some wood ramps are the quickest, best option. I expect it to take some experimentation to get an effective set, though. Buy some two or three foot lengths to play with. All the best.
Im hoping it’s mlstky the skirts. It’s bad though. I haven’t taken the car out again. I start work in a Week. Need to find a solution by then. Worst case, I will buy a bunch of plywood to raise the whole dip side. It sucks because it’s such a high peak and a long dip in either direction.
My suggestion is to use 2 pieces of 2x8 between the wheelbase that you would put in place as you enter the garage. or on the street side of the ramp when exiting. Looking at the picture, I would think they would need to 3 to 3.5 feet long. The procedure would be (either entering or exiting) is to drive to a point where the front wheels are at the highest point. Then place the 2x8s so that they are one the street side with one end at the juncture of the concreted and pavement. Then slowly drive over the 2x8s. After that, stop and put them in the car. I would angle cut the ends at about 45 degrees. If one board is not high enough, I would add a shorter piece on top near the end that is closest to the street. Probably 1.5 to 2 feet long.
I made ramps out of 2x4s on their sides (3.5 inches high) that I can slide under the front or under the rocker panels so 2 pieces of 2x8 one on top of the other would be 3 inches high so they should clear.
For the bottom of the ramp, if you can angle it, I would just do that. Also, if it is just the air dam pieces under the nose that is scraping that is no big deal as they are designed to take some scraping. Mine scrape going in and out of driveway with no issues.
Hope you can get this figured out.
Received 2,051 Likes
St. Jude Donor '13
GM publishes "Trim Height" (ride height) numbers in the Service Manual for each model, including a set where you simply measure from the pavement to the top of the wheel arches. I don't have my copy scanned yet but someone else should be able to post them here. Measure with full gas, no people or luggage, tire pressure set, level pavement. Tire wear will reduce the height and I correct for that. Repeat several times, driving between times.
Our C6 Z51 was at or slightly below the official height but did not scrape. Our 2017 Z51 was about the same but scraped parking lot speed bumps several times when we visited Phoenix in winter. I had it adjusted up to exactly stock height and the scraping seems to be gone. Each turn of the bolts will raise/lower that corner of the car about 3/32" when measured at the wheel wells.
Having said all that, it will take a lot of adjustment to fix OP's problem.
Easiest thing to do is raise it back up like everyone says. That or either cut some wood to put down. If you're sharing the drive with folks its gonna get old putting it in and out daily. Reason the Mclauren is able to clear is he can adjust height from inside the car to remedy the problem.
1) raise it
2) install sliders/rails if available. I know they are available for C5, C6, not sure about C7.
3) find an offsite garage if needed. sounds crazy but I bet you can get one for around $100/mo
good luck!
good luck!
I made some very simple ramps out of plywood. Stacked various lengths in layers to match the dip before my garage. Works perfectly, cheap, and you can have the store make all the cuts if you don't have the equipment.
Then I painted them to match my car because I'm a dork...
Geez, that sucks, and would freak me out too!! They should include a clause in the lease that indicates that the parking lot is an SUV only zone...I hope you find a workable solution.
You need to move to a different apartment complex. Eventually you will destroy those rocker panels, and they are NOT cheap to replace.
Just looking at that gives me nightmares. That is a fairly long steep incline with a sudden level/drop so it isn't going to be easy to overcome like those little valleys between a driveway and street. I expect my ATS would be a close call given that bizarre layout; my GMC 2500HD would be fine except the clown that designed that approach probably also included a 6' clearance somewhere just to screw everything up.
If the ramps cannot stay in place I couldn't deal with putting them in place twice a day. If you are locked in on a lease, find safe offsite storage for your C7 and pick up a beater or motorcycle to get back and forth to the C7 when you need a real car. If moving is an option carefully get the car out and move somewhere with less goofy parking.
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
I know I can't fathom the hassle of having to drag out ramps every single time I came and left my home. Best of luck, man!
Take off the side skirts.
Raise car on stock bolts as much as possible.
Drive with 1/2 tank or less of gas.
