C7 Battery Life, 2014 38,300 miles
Old 08-11-2018, 09:14 PM
roadbike56
Support Corvetteforum!
roadbike56's Avatar
Received 1,609 Likes on 1,037 Posts
St. Jude Donor '16-'17,'22,'24
I just replaced mine this week. Based on the "in service" date, the battery was 4 years and 4 months old for a Delco Silver, three year battery. I decided I pushed it long enough and replaced when it was in the Chevy dealer for an oil change. Hendrick did the work (and they didn't tear the carpet). I went with the gold, 42 month battery.
Old 08-16-2018, 10:06 PM
ImpliedConsent
ImpliedConsent's Avatar
Since we're on the subject. I understand that the battery is DIN size H6. Optima's website search does not show a battery for my 2016. I don't think their database has kept up with marketing: OPTIMA® BATTERIES UNVEILS A NEW OPTIMA YELLOWTOP® WITH DIN FITMENT . Does anyone have the new H6 Optima Yellowtop? "It will be available for purchase in the spring of 2018 in DIN group sizes H6 and H7." I can't find it locally either.
Old 08-17-2018, 08:18 AM
JerryU
E-Ray, 3LZ, ZER, LIFT
JerryU's Avatar
Received 9,598 Likes on 6,612 Posts
Have to be careful. The top structure has to be able to hold the large power board on the positive terminal. It clips to the straight side battery with recessed terminals (trick is to find the clips!) There are other batteries with the same dimensions that fit the hole but don't have that specific shape. Just bought an Optima Yellow Top for my Street Rod but for the 2014 C7 bought a more conventional AGM battery that said it fit and it did. Mine was a Diehard but Autozone and Advanced Auto had the same one with their brand name. Batteries are made by a few major suppliers that put whoever's name on them.
ImpliedConsent (08-20-2018)
Old 08-17-2018, 08:23 AM
Kracka
Kracka's Avatar
Received 5,675 Likes on 2,897 Posts
I plan to do the same next time I'm in at the dealer (March 2019) assuming my factory battery lasts a full 5 years. Sometimes it seems like these fancier batteries are more trouble than they're worth so I'll be doing the same as you - ACDelco Gold.
Ron_Attleboro_MA (07-11-2021)
Old 08-17-2018, 10:57 AM
JerryU
JerryU's Avatar
FWIW, AGM batteries are proven technology. Wife's BMW SUV come with one.
The Optima Yellow Top AGM battery in my Street Rod was just replaced after 10 years! It was working find BUT it's locked inside the car with electric doors and no handles. Was concerned that it might fail at a Car Show! When in the garage I have a way to power the driver's door solenoid latch but that requires another battery and crawling under etc.
In fairness, that Yellow Top is always on a maintenance charger. That does help battery life. The AMG battery I put in my C7 had 760 Cold Cracking Amps versus the OEM that had 565. Your car your choice.
Old 08-17-2018, 11:27 AM
ImpliedConsent
Originally Posted by JerryU
FWIW, AGM batteries are proven technology. Wife's BMW SUV come with one. <snip> In fairness, that Yellow Top is always on a maintenance charger. That does help battery life. The AMG battery I put in my C7 had 760 Cold Cracking Amps versus the OEM that had 565. Your car your choice.
I'm a fan of AGM as well. I rock crawl with my Subaru and getting some weird angles. Always worried about acid shift and offgassing of LA batteries. I'm a firm believer in AGM. CCA if fine to get it started, but I'm more concerned with higher reserve capacity. I couldn't imagine the work the battery does on a start/stop eco car.
JerryU (08-17-2018)
Old 08-17-2018, 08:05 PM
dino333
dino333's Avatar
Default Battery replacement.
Originally Posted by Kracka
I'm sure I'm nearing the end of the road with my battery. 2014 w/41k miles on it here in Texas. Hoping it lasts until March (will be my 5 year mark) then I'll just have the dealer do it during the annual inspection and engine coolant flush.
2015 Stingray with a little over 18,000 miles.Went bad this week.Had it replaced with a AC Delco Gold battery.
Quick Reply: C7 Battery Life, 2014 38,300 miles
