Why I am happy I never lowered my C7
So, I am driving my C7 down the main street of the small southern town I live in, when I come upon an extended area in which they have dug up the asphalt and have left manhole covers elevated at least three inches above the street. I grimace as I carefully drive over each one, praying I don't hit any of them. I can't change lanes because traffic is too thick. I slowly make my way over manhole after manhole, at least a dozen or more in the short stretch of road. I never hit any of them and all I can think of is, "Thank heavens I NEVER lowered this car. Thank you, thank you, thank you..."
The following 6 users liked this post by LIE2ME:
Avanti (08-14-2018),
Carvin (08-15-2018),
Corgidog1 (08-22-2018),
pdiddy972 (08-13-2018),
Rebel Yell (08-14-2018),
and 1 others liked this post.
The following 3 users liked this post by PatternDayTrader:
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
I lowered my ‘14 all the way on the stock bolts when I bought it over 4 years ago. It’s my daily driver. I’ve never wished I hadn’t. To each their own.
The following 5 users liked this post by Steve_R:
BlueDevilZ51 (08-15-2018),
fugly1 (08-14-2018),
jdk541 (08-14-2018),
Joe_Joe (08-14-2018),
owc6 (08-13-2018)
It appears that if your wheels are on either side of that small recessed area around the manhole, you are still at street height which is where top of cover is (flush). BUT, man I would hate to be driving at any speed & have a tire/wheel drop into that hole around the cover & impact it. Talk about a bent/cracked wheel/alignment problem-WHEW!
There's already insufficient suspension travel for the typical public roads where I live.
It does look better though.
Received 3,114 Likes
Finalist 2020 C7 of the Year -- Unmodified
I drink GM KOOLAID ! If it came from the factory a certain height that is how mine will stay...……….
The following 5 users liked this post by Always Red Dave:
Corgidog1 (08-14-2018),
dvilin (08-22-2018),
Mayor111 (08-14-2018),
SoCalFinest (08-13-2018),
Strake (08-14-2018)
Moderator
Yeah mine is low enough already. If it were a waxer then maybe. Just as long as I could get it on and off the trailer ok.
Some (if not most or all) of this comes down to how yours came from the factory. Mine looked like a 4x4 in comparison to either of my C6s and other C7s, so I had my DD lowered all the way on factory bolts.
The range that the C7 has is enormous. All variations are within factory specs.
FWIW, I have yet to hear why they are coming out of the factory with over an inch difference between one extreme and the other.
Factory ride height specs are below. Measurements are taken from the ground vertically right over the wheel center to the center point of the fender lip. For proper suspension performance it should be within these specs.
Boiler_81 (08-14-2018)
That’s funny, but true. Maybe add air shocks, operated by the key fob as an (older than most) option. Raising the whole car up about a extra foot for easy entry, and exit. Jk
The following 2 users liked this post by L8ter:
bjones7131 (08-14-2018),
Oskee (08-14-2018)
4x4 look? Come on, not even close.
I will never lower mine. Stock height takes a lot of trouble out of play. Keeps me from any issues with speedbumps, most parking curbs and potholes.
And yes, it looked like a pregnant cat, all tippy toed... (yes, lowered on stock bolts.)
luv2sail21 (08-14-2018)
The car is low enough as it is.
