Primer color???
Primer color???
First off I know nothing about painting cars. So this question might sound a little strange. Why, when you have a black or dark colored car the primer is white, and when you have a white or light colored car the primer is black? Is it so you can see the nicks better? I have a need to know!!
Gray primer is fine - you can use 3M green putty for light scratches - to check you body work you can spray a light coat of black lacquer resand until your happy with body work and scratches are gone - re-prime in gray sand for paint done
FYI never use bondo with red hardener especially on a white car it will bleed continuously and you will see it thru the paint forever
Thanks for the replies. I have a 2017 Arctic White GS. I got a nick in the paint the other day and it was black under the white. I also had a 2014 Stingray in Cyber Grey and it was white under the gray. Why?
Do not use red hardener you have a white car how convenient lol - primer color does not matter used gray for 35 years thats fine
Try to keep repair contained to just the nick area as not to spread out more on panel - this keeps area to be repainted a lot less - you could put masking tape around repair area as not to sand more then you need to - depends how deep it is - putty may not be ideal its for only final sanding step really
If its a shallow chip I would try just green putty will be a lot cleaner - putty does like to draw in if its to deep
You could use a tiny amount of bondo let it rise above flatness of panel a little bit to give you leeway to sand down to the panel for a nice repair - not enough to sand away it will be low
You will have to sand and re prime a few times depending how good you are with body work
Keep in mind you mask off the area you will have hard line primer marks that need to be sanded - wet sand if possible - its much cleaner wet sanded - flatten primer out (no hard lines) then you prep surface for paint
Any pics easier to give you hints after seeing where it is and what panels are affected
Received 5,208 Likes
A "nick" could mean anything, let alone "where."
