Key Fob Remote Help
SyberSaint (09-04-2018)
Assuming you're not locked out?? Try placing the FOB in the slot on the right side of your steering wheel. That's where I had to put mine the last time I got a "No Remote Present" pop up on the screen.
You can start your car with a dead fob battery in the steering column slot. Heck! you can start your car with a fob w/o a battery in the steering column slot.
Maxie2U (09-07-2018)
SyberSaint (09-07-2018)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Lisa is correct. You don't even need a battery in the FOB to insert it into the slot and start the car. As long as the FOB is "linked" to the car and the FOB is functioning, the slot will allow the car to start. The OP asked about a dead FOB battery, not a bad FOB.
Elmer
Elmer
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Pulled both FOB batteries and checked with a meter I have had for years that puts a load on the battery depending on size. Both the one from the FOB that did not work and the one that had not been used for almost 3 years read barely in the green OK area! Bought two quality batteries and not like the cheap one from China I got on eBay a year before! All was fine.
Appears to me the FOB needs to be relatively high voltage and won't work when weak. When my Grand Sport is two years old will replace the FOB battery. Also looks like it drains even when not in use!
All he has to do is use the FOB not detected checklist in this thread: http://forums.corvetteforum.com/c7-g...s-and-rke.html and it'll walk him directly to a solution.
Elmer
