What would you add/change/remove and what is useless
Old 09-14-2018, 05:33 PM
  #61
Slynky
Support Corvetteforum!
Slynky's Avatar
Originally Posted by defaria
Oh it does smooth out downshifting, especially when you're zipping around windy roads as I said and you want a continuous flow into the next lower gear because your nailing the turns. But when your say coming to a stop light on a straight line with a right turn coming up and you take it out of say 5th gear aiming for 4th gear but as you travel towards 4th gear you get close to 2nd gear sometimes the Rev Match blips the throttle as if you're heading into 2nd and your engine needlessly roars up the RPM. That's the effect I'm saying that makes me feel as if I'm somehow trying to show off to say pedestrians. It's needless and wastes gas. And really, in such a driving situation I don't really need, nor intend to use that Rev Match.
Yeah... I think I know what you're saying. My Z does that, too, at odd times and I wonder what "it's thinking"... LOL... I guess it's just confused by my motor RPM. Thanks!
Old 09-14-2018, 07:05 PM
  #62
Skid Row Joe
Skid Row Joe's Avatar
Received 3,962 Likes on 2,872 Posts
ALL the spoilers are; "aerodynamically useless," other than as rear-end dirt collectors. If anything, they're deleterious to mpg, at the low speeds they're driven at off-track. Storage "in the convertible waterfall assembly," should have been built into them. Pretty much a near perfectly engineered machine otherwise.... 👍
Old 09-14-2018, 07:19 PM
  #63
SuperdadZ06
SuperdadZ06's Avatar
#1 for me would be lane departure warning both on side mirror and audio alert.
Old 09-14-2018, 07:35 PM
  #64
George_L
George_L's Avatar
Improve the shifter for the M7. I installed an MGW and it is a huge improvement. Maybe Chevrolet should partner with MGW.
SuperdadZ06 (09-14-2018)
Old 09-14-2018, 08:28 PM
  #65
SuperdadZ06
funny you mention that, it was on my list of mods but I have nothing to compare the stock shifter to which i like. What didnt you like about it and how is the mGW an improvement?
Old 09-14-2018, 09:52 PM
  #66
George_L
George_L's Avatar
I can't say that I really disliked the stock shifter that much, I just felt it could be improved if that makes any sense. The MGW has a much more solid feel and there is more positive feedback when a gear is engaged. The gates have a different feel to them also. I feel that it takes slightly more force to move to the 1-2 or 5-6 gates and even more to the 7-R gate. Another way to say it is that the centering spring feels a little stronger. The throw is also a little shorter. Others have compared the shift action to a bolt action rifle (solid and positive). I fully agree with their assessment. Could I have lived with the original shifter; sure. Could I go back; not willingly.
If you are ever up in the Albany-Saratoga Springs NY area drop me a PM and I will let you try it.
Slynky (09-14-2018)
Old 09-14-2018, 09:56 PM
  #67
Carvin
Carvin's Avatar
St. Jude Donor '15-'16
Have a way to manually lower the screen to access the storage area in case the screen gets stuck.
Give us Z06 wheels that will not so easily crack!
Old 09-14-2018, 10:14 PM
  #68
Skid Row Joe
The C7 isn't "confused." If YOU are not driving it properly, you're the one confused on how the M7 operates. Would suggest, you don't engage the rm, or, change shifters....
Old 09-14-2018, 11:38 PM
  #69
SuperdadZ06
That is a very kind offer, how far are you from the NJ border?
Old 09-15-2018, 11:25 AM
  #70
ImpliedConsent
ImpliedConsent's Avatar
I don't even understand this. The rear compartment screens? They get in your way?
Old 09-15-2018, 11:29 AM
  #71
George_L
George_L's Avatar
I'm in Burnt Hills, NY 12027. You can google it. I'm about 30 minutes north of Albany.
Old 09-15-2018, 11:30 AM
  #72
2500 hd
2500 hd's Avatar
St. Jude Donor ‘18-'19-'20-'21-'22-'23-'24
Was it difficult to install ?
Old 09-15-2018, 12:10 PM
  #73
George_L
George_L's Avatar
Not if you take your time and follow the videos. Getting the rubber boot installed took some playing around. I ended up using some plastic trim tools that worked well. Some people have trouble getting the shifter boot off but mine had been removed before I bought the car and they broke one of the small protrusions off so it was easy. The broken part doesn't seem to have any effect on how it looks or performs. I don't want to hijack this thread so PM me if you have any additional questions. I'm happy to try and answer them.
2500 hd (09-15-2018)
Old 09-15-2018, 07:57 PM
  #74
NoRuls
NoRuls's Avatar
Originally Posted by Maxpowers
Add: The ability to adjust the steering stiffness while in PTM Wet
When I had my C6 I asked to have the speed sensitive steering disconnected so it would be easy to steer at all speeds. And the answer was "NO it can't be done". No definitive answer as to why,, just "NO"
Old 09-15-2018, 08:15 PM
  #75
montanaman
montanaman's Avatar
Heated seats in my 2017 C7 base 2LT are weak. Can only barely feel them on high. Cooled seats are just ok on high.
Blind spot monitoring should be stock. Especially on this car.
Better infotainment .....but it's not terrible.
Seat belt clip holders. Not sure why they haven't changed that.
GM mud flaps should be standard.
Rev match switch should be a single button somewhere but I know why it is like is.
Top installation is a little fiddly on mine.
Anything else would be nit picking. Over all fantastic car so far.
j14152 (04-20-2021)
Old 09-16-2018, 10:07 AM
  #76
malexand123
malexand123's Avatar
Add:
heated steering wheel
rain sensing wipers
auto high beams
auto darkening mirror on all 3
Old 09-16-2018, 11:48 AM
  #77
joemessman
joemessman's Avatar
Received 3,436 Likes on 2,057 Posts
You guys keep adding amenities the car is going to weigh 4,000 lbs!
Old 09-17-2018, 02:15 AM
  #78
fumbling
fumbling's Avatar
I've test driven cars with lane departure warning and steering wheel feedback that pushes the car back into the lane and it is incredibly annoying. I can't imagine an audio alert to go along with that. This would be the last thing I want on a C7/8.
Old 09-17-2018, 07:04 AM
  #79
2016C7.paul
2016C7.paul's Avatar
Change: Paddle (or Rev Match) shifters that are not so cheap and flimsy that you can hear them when you use them. Heavier, metallic paddles that are standard in the Euro-trash cars are a no-brainer.
Add: An option to enable/disable the crappy center audio speaker so that those of use who appreciate true stereo can turn it off for music and turn it on again for other audio applications like talk radio.
Add: 4 holes, not 2, for the rear license plate frame so we don't have to creatively augment the rear end to accommodate 4 hole 3rd party license plate frames.
Change: Give us a stingray exterior side trim piece that does not suck, like the GS or Z06 have. Why do I have to decide whether to perform an abortion on my side trim because I am a base model buyer?
Quick Reply: What would you add/change/remove and what is useless
