Major change in gas mileage
8th Gear
C7, 2015, 21k miles. Previously 19-20 mpg. I知 74, I知 more into the style than speed. Recently, I知 gettin 15 mpg with no change in driving habits. Actually, I致e tried to get better mileage. NoJoy. Thanks. Sandy
Received 19,289 Likes
'20-'21-'22-'23-'24
May want to take it in to the dealer (especially if under warranty) and have them take a look at it. That’s a pretty significant drop in MPG.
Sandy,
Two questions: How are you measuring your mileage, and have you changed your driving conditions when you saw the difference. For example, stop&go driving will kill mileage over a short distance. To really find out if you're having a problem first I'd measure your mileage old-school, miles driven on a tank / gallons pumped.
HTH, and have a good one,
Mike
Mike
Received 1,400 Likes
Double check mileage the old fashioned way, and other than a change from more cruising to more city driving, suspect something like the oxygen sensors. These do not necessarily set a code until they are dead-dead, instead of on-the-way-to-dead.
I have seen reports of significant mileage drops with other GM engines due a sensors and actuators in the VVT system. It appears these items can be "sick" for a long time before they degrade enough to set a DTC. If this is the issue you are more likely to get a failure and set one or more DTCs along with a check engine light by operating the engine over a wide variety of conditions. Now is the time to drive it a little more aggressively including harder acceleration and also shifting so that it sees a higher RPM range (use manual mode if you have an automatic transmission). This type of driving will typically expose a "soft" error sooner rather than later.
My 2014 Cadillac ATS with the 3.6 direct injected engine had a slight but noticeable drop off in MPG and after two weeks it finally set a DTC and turned on the CEL; one of the cam phase sensors was failing and once replaced mileage returned to normal. I never noticed a change in power level with that engine and I do a lot of passing on two lane roads but the mileage drop was readily apparent.
I would also switch fuel stations because your current supplier may be feeding you regular octane through the "high test" pump and if so your engine is often running with severely retarded timing courtesy of the protective knock avoidance system and sensors.
+1 👆 Very good PDT. This article supports your point.
https://auto.howstuffworks.com/fuel-...mmer-fuel1.htm
Check alignment.
Check tire air pressure.
Brake(s) may be dragging.
Change gas station for different gas.
Winter blend gas has between 95 and 98 percent of the energy content of summer blend gas so even if he is burning winter blend already it won't account for the 20-25% drop in mileage. The primary reason winter blend seems to give so much worse mileage for some people is because operating most cars in winter is simply far less fuel efficient. Warm-up is longer, a lot of people needlessly idle the vehicle, tire rolling resistance increases, a lot of owners don't properly maintain tire air pressure when the temperature drops, etc. I live in Central IL and my year around daily driver (ATS with 3.6 engine) loses at most 1 MPG average over the very cold months (far less than 5% from summer average).
Diesel fuel can have a far greater BTU per gallon spread between summer and winter in areas where much lighter distillates (like kerosene) are heavily blended in to prevent fuel gelling but even then a 25% drop in mileage would be largely due to driving conditions and not just the fuel.
Agree with confirming the mileage using the "old school" method if not done already. Any of the other suggestions could contribute, but a confirmed drastic change in mileage driving equivalent routes points to a problem with the car instead of external causes. Interested to hear the result and fix!
Received 2,639 Likes
8th Gear
Thanks for all the responses
Rebel Yell (09-14-2018)
Assuming you don't have any other symptoms, it's almost as if you're running E85 (not saying you are, just trying to visualize the scope of the problem.
Could you make a highway run for 200 miles or so and see what your mileage is? Just trying to minimize the variables in city-style driving.
Good luck, and have a good one,
Mike
Is the wife going for joy rides without you and killing it?
I would take it in for a check. Have you checked for any codes?
Manual or automatic? If auto, do you use the manual shift option?
Holding in a lower gear than need be can / will drop mileage really quick.
Ex: due to traffic light spacing and timing, my daily commute usually does not exceed 40 mph / 2nd gear.
But I‘ll only get 14 mpg if I stay in 2nd.
If I go to 3rd, then I‘ll get 17
granted, get some nice exhaust noise in 2nd....
Similar results with 5/6 or 6/7 on the interstate. 5mpg+ difference.
4/6 or 5/7 has an even bigger difference.
