Look what I found in the catch can
I've pulled the intake on my 2015 C7 and 2017 Camaro SS. Guess what? The valves looked fine. Needing a catch can on a stock or bolt on LT1 is rubbish.
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Is coking an actual problem? I don't think so.
I can tell you all that at 80,000 miles (few of you will ever see such milage on yours, BTW), mine broke a valve spring, and there was no evidence of coking. "Clean as a whistle" is what they said.
The following 3 users liked this post by owc6:
Huh, more objective evidence.
Maxie2U (09-17-2018)
Replacing a valve spring consists of removing the spark plug, then forcing compressed air into the cylinder (usually using a compression gauge hose) so air pressure holds the valve against its seat, then compressing the spring with a spring compressor (looks sort of like a miniature gear puller sort of), then you remove the valve keepers and the spring retainer, then you put it back together with a new spring. Its an easy job. The valve never comes out of the head. You don't even pull the intake manifold.
The following 2 users liked this post by PatternDayTrader:
CorvetteBrent (09-19-2018),
PDT, so what you are saying is that when they replaced my valve spring, they never even had a chance to look at the back side of my valves?
I suppose if thy were stupid, then maybe they pulled the head off the engine, and made tons of work for themselves, and made your bill at least six or seven times higher than it should have been. Its not impossible. There's a lot of stupid people in the auto service industry.
OK, can you explain how the repair was done?
#33
Don't get me wrong on this. Valve coking is a non issue, unless you have a mostly worn out engine to start with.
#34
#35
I would guess that when he was asked the question, he probably thought he was being asked how clean the engine was under the valve over, because you do take the valve cover off.
#37
$0.
Covered under Drive Train Warranty.
'14.
But anyway, how was this repair performed, then?
'14.
#38
Provide some facts beyond your bias opinions.
#39
Basically you pressurize the cylinder so the valve stays in place, then you remove the keepers and the retainer, then the spring, then reassemble with the new parts.
Under normal circumstances, the entire set of 16 springs can be changed in two hours or so, maybe three.
At no time do you see the valve head. Only the valve stem is exposed under the valve cover. Which is an interesting point about valve coking, if the stem is sloppy in the valve guide, then oil will be sucked into the intake port (in very small amounts), surface tension will keep the oil in contact with the stem in the intake port, and as the valve moves up and down, this oil is scraped onto the valve head, or just above the valve head. Eventually this will turn into the coking problem. So a catch can wont help, because crankcase ventilation is not where the coked oil comes from.
The following 3 users liked this post by PatternDayTrader:
#40
