Are side skirts and front splitter riveted on ?
I have a 2019 grand Sport and want to change the factory short side skirts and fr. splitter. How do you get these off are they on there with rivets??
OP is correct !! I believe one bolt in front and one in rear. Drill out rivit heads. no big deal. probably will take you about 15 minutes a side.,
Don't drill deep.Drivers side has the tranny lines in the rocker.A drill stop is your friend.
Working from middle to sides will get you a tight install.Fender washers on the small rivet heads will give more holding area.Stainless hardware is a must.Skirt info only.Havn't dun splitter
No rush,take your time
Maxie2U (09-24-2018)
Supporting Vendor
You may check out our C7 collection if you are trying to purchase any exterior parts for your Vette.
Best Price | Free Shipping | Easy Installation
If you have an A8 be very careful drilling holes for the rivets on the left side because the transmission lines run very close to the bottom of the rocker panel.
If you drill through one of the lines you will be really really screwed. There is no easy way to repair or replace those transmission lines.
Moderator
Also there are better fasteners to use than rivets when you put the new pieces on. Are they called Scrivets or something like that?
Ummm... Place chisel on exposed part of rivet. Hit chisel...
Seriously, though. I would just drill them out. The indented nature of a rivet means you're going to go dead center every time when drilling. Very minimal risk. Just use a drill bit stop (or a bunch of electrical tape around the bit like I did).
JerryU (09-25-2018)
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
In fact I was able to slip a piece of sheet metal behind the rocker panel before I drilled to stop the depth. The composite material drills like butter. The only issue is physiological- drilling the first hole! Once that is done it's very easy!
PS: For the person who for whatever reason does not want to drill them out if that were needed, that stainless washer can make the chisel method work great! The holes are very close to the bottom so only an ant would see them if the skirts were removed!
LbulletM (09-25-2018)
St. Jude Donor '17, '19
As for new ones, if you want to rivet the new ones on, you will need rivet gun.
Received 8,928 Likes
What you want are 3/16 large head aluminum rivets. If you have enough room behind the panel exploding rivets may work even better. No need to monkey around with washers with the large head rivets.
Here is what the backside of the exploding rivets look like
Here are some choices on the Speedway website:
https://www.speedwaymotors.com/Multi...250,24384.html
https://www.speedwaymotors.com/Large-Head-3-16-Inch-Exploding-Rivets,42816.html?sku=910049-PLN&utm_medium=CSEGoogle&utm_source=CSE& utm_campaign=CSEGOOGLE&gclid=Cj0KCQjwuaf dBRDmARIsAPpBmVV5EanMPv1jeBLXLZJ8XH9YAWd S8BXZs96l47-OHwI04TxM3cKa4hgaAoDNEALw_wcB
Bill
Bill
duanesZ06 (09-25-2018)
This video offers some good details on installation:
https://www.youtube.com/watch?v=Hwp22VYmPVU
