How to change rear pads?
Been a couple of years, so I am operating off of memory. Give me a day or 2 and I will know for sure as I am putting ceramic pads in my new ATS-V (same calipers). But I remember a very slight change. The fronts had an extra small step. The back is just the pin. And if you have a punch that works on the front you can use it on the back.
jsg1518 (10-16-2018)
bankers1 (10-17-2018)
I use a very small Robo-Grip style locking pliers in combination with a small plastic / nylon head hammer. Grab the pin with the pliers and lock onto it, then tap the pliers with hammer. Ensure the pliers don't slip (keep them locked tight) and use small short taps. Because your grabbing the pin from INSIDE the caliper vs the outside with a punch you gain some extra space to work. I use technique when removing the old pins too. As the pin slides in (or out) you might have to reposition the pliers. The fronts are easier since you can turn the wheels.
I've thought about using a wooden dowel since you could sand it down to be just a bit smaller then the hole plus cut it to your desired length. Of course being wood you would have to be careful not to split it when whacking with the hammer. Good news is that wouldn't damage anything since the wood is so soft.
And I suppose I may have "drifts" as my punches are not tapered. They are sized but are the same circumference for about 3 inches than you have the wider handle.
I do have a set that are tapered buy not the best tool for this job.
Miller Time Wisconsin 🍺
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
The rear pads are easier to change than the fronts. An old drill bit can be used to tap out the pins. Jacking the car and taking the wheels off are 90% of the work.
JMII (10-17-2018)
I got a set.. problem is they are tapered. So they work fine to start the removal process but at some point the tool is flared too much (larger diameter) and your forced to stop hammering it. Also the overall length means that during the insertion process you can't fit the pin, punch and hammer into the space available.
I can replace all brake pads and wheels off 1 floor jack in about 20 minutes now. I use:
Stubby hammer.
Punch set (I cut 1 punch in half to use it for pushing the pins back in on the back wheels as space is limited.
Channel locks and a rag.
i press the Pistons back in by hand.
I do this twice a month for track days.
