If you are on the fence regarding x-pipes...
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
Just hit 504 miles on the Grand Sport, so I did an oil change and decided it was time to throw that Borla 60547 xpipe I had on it. I've been here 2 other times with other C7's, but it never ceases to amaze me just how big of a difference these things make. WOW.
The video is just a quick start and comparison of idle since I can't simultaneously record and rev the motor at once. I'll get that video tomorrow or something.
The following 12 users liked this post by devnull:
A320Flyer (10-27-2018),
Bigfoot16 (10-27-2018),
HooosierDaddy (10-27-2018),
Mike Campbell (10-30-2018),
robert miller (10-28-2018),
and 7 others liked this post.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Everything else is stock?
For $350, that seems like an easy and worthwhile mod!
How's drone ?
How's drone ?
devnull (10-27-2018)
Everything else is bone stock still, temporarily haha.
Received 19,275 Likes
'20-'21-'22-'23-'24
The X-pipe made quite a difference. Great choice.
Sounds great! Is there any tuning that needs to be done to keep engine light off after removing the cats?
I waited until almost 9000 miles to install my corsa x pipe and I wish I had done it on the day I bought the car. I have zero complaints about the way my car sounds now. That initial bark from the tailpipes on a cold start without the second set of cats is just incredible. Ear to ear grin every time I start this car.
Nothing. Those cats are not monitored (behind the second O2 sensors)
Few pics from the install...
Couple of notes:
Torque specs I used...
Tunnel plate small bolts (22) - 20 ft/lbs
Tunnel plate large bolts (2) - 74 ft/lbs
X-pipe hanger bolts - 16 ft/lbs
X-pipe to manifold stud bolts - 18 ft/lbs
Borla clamps - 35ft/lbs
The front most tunnel plate small bolts will seem to tighten forever. There was a bit of glue under the plate on the chassis for mine and so it seemed to tighten but still went through several turns before torque spec was reached. This is not a big deal, you are not stripping it.
Use some dawn on the rubber grommet/hanger to slip it on with ease.
Clean the pipes with alcohol before putting the plate back on you greasy slob (maybe I am deflecting a little)
Couple of notes:
The following 5 users liked this post by devnull:
A320Flyer (10-30-2018),
got2hav1 (11-16-2023),
JMII (10-27-2018),
Rebel Yell (10-28-2018)
Received 1,762 Likes
ttt
Buddy look at that exhaust tip on the pass/side it looks a little low & to close to that next tip. Just kidding here but I know now you will go and look or even do more. Robert
HAHAHA!!!
EDIT: Wait, it DOES look a little low! Screw it, I'm putting the ATAK on anyway.
Last edited by devnull; 10-27-2018 at 10:46 PM. Reason: Because I am insane and really did check
Why does Borla website have the following warning listed under the x-pipe product?
“LEGAL ONLY FOR RACING VEHICLES THAT MAY NEVER BE USED, OR REGISTERED OR LICENSED FOR USE ON A HIGHWAY”
Your initial comparison sounds like stock x pipe, cold start, flaps closed vs borla x pipe, cold start, flaps OPEN, not flaps closed like the stock x pipe flaps were closed.
Exactly what I'd expect without MTW
devnull (10-28-2018)
flaps were open on that first part too. Only time they were closed was at the end when I was playing with the M2W switch. I do wish I had the actual startup in that first part, but I don’t have the video (would’ve been a good comparison).
Take another look, you'll see them open in that first part.
thanks
