Just a little BlackFire for you - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 11-13-2018, 12:25 AM
MJC611
CF Senior Member
Originally Posted by Custom Corvette Accessories View Post
Did the following
-Blue Dawn Wash
-50/50 Alcohol/Water Wipe Down
-Blue Dawn Wash
-Clay Bar
-Blue Dawn Wash
-Black Fire - 2 Towel
Everything above the BlackFire was done to remove the product that was already
on there (Rejex)
Chip
When putting BlackFire over Zaino is this sequence necessary? Is the alcohol you mention regular rubbing alcohol?
MJC611 is offline
Old 11-13-2018, 12:33 AM
Premium Supporting Vendor
Custom Corvette Accessories's Avatar
Basically you want to take the zanio off.
The alcohol wash and clay bar will do that
I use denatured alcohol, get it at the local hardware store
Chip
__________________
Corvette Parts and Accessories
Custom Corvette Accessories is offline
Old 11-19-2018, 02:27 PM
Inferno18
CF Senior Member
Inferno18's Avatar
I purchased a bottle of Blackfire the other day and decided to give it a shot. It is partly sunny and 50 degrees with no wind in South Jersey today. I figured the weather isn't going to get any better than that so it was now or in the spring. We still have a little snow left on the ground from the snowstorm last Thursday.
Inferno18 is offline
The Following User Says Thank You to Inferno18 For This Useful Post:
CCA Corvette Parts (11-19-2018)
Old 11-19-2018, 02:32 PM
vader86
CF Senior Member
vader86's Avatar
Bought a few bottles on Autogeek, had a coupon for a chunk off.
vader86 is offline
Old 11-19-2018, 02:36 PM
Inferno18
CF Senior Member
Inferno18's Avatar
I bought mine on Monday from Auto Geek. They were having a 25% off sale on everything. I got it for $36 plus they threw in 3 of those supreme 530 microfiber towels for free.
Old 11-19-2018, 02:49 PM
CamarosRus
CF Senior Member
Chip, I understand all the washing, claying and removing or previous waxes, etc..................
but WHY would anyone want to apply the BLACKFIRE (above) and not remove
ANY scratches, defects that certainly must be on most Corvettes..........
I've been working to remove all my clear coat chips, scratches with a Meguairs Micro Fiber
Cutting Disc and Either Meg's 105 or 100
CamarosRus is offline
Old 11-19-2018, 02:55 PM
CCA Corvette Parts
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
I'm with you, clean up whatever you can before you lay it...
Regards
Chip
__________________
..................Click for
CCA Corvette Parts is offline
CCA Corvette Parts
I know, crazy on red...right...
Regards
Chip
__________________
Old 11-19-2018, 03:03 PM
Vet Interested
CF Senior Member
Vet Interested's Avatar
Originally Posted by devnull View Post
After over 18 years of being a Zaino only guy, you just broke me Chip (I ordered a bottle). Powerful image you have up there! Can't wait to see how it goes...
Me too. I am really considering this.
I am curious how this compares to installing Zaino. Easier, harder, takes more time?
Vet Interested is online now
Old 11-19-2018, 03:23 PM
Inferno18
CF Senior Member
Inferno18's Avatar
Not even in the same ball park. It is absolutely way easier. I'm just talking about the blackfire step here, not all the prep like washing, clay bar and machine polishing out scratches. You just spray it on a microfiber towel as opposed to spraying it directly on the car to avoid overspray and wipe it on. Then immediately take another clean microfiber towel and wipe off the product, turn the towel and buff. That's it! From everything I've read you don't even wait for it to dry before you start wiping. I guess to prevent streaking. Also do small sections at a time to prevent streaking. I was lucky, I did a minor paint correction last week and put it back in the garage. So today I only had to apply the blackfire. It is absolutely KILLER on red!
Vet Interested (11-19-2018)
Old 11-19-2018, 03:28 PM
Inferno18
CF Senior Member
Inferno18's Avatar
One other thing, I did not use a microfiber towel to apply the Blackfire. I used a Hex Logic black applicator pad. I sprayed the blackfire right on to the pad and used a gentle sweeping motion to apply it. I believe that by using a finishing pad instead of a microfiber towel you will use even less product. It was almost too easy.
Old 11-19-2018, 03:36 PM
Dif
CF Senior Member
Support Corvetteforum!
Dif's Avatar
I started with Zaino in 2009 for my Corvette, then shortly afterwards used Rejex from then on.
This July I bought one of the last containers of Black Fire Crystal Seal before it was discontinued and will not be looking back.
My Shark Gray still looks like it did the day I applied it and it's holding up longer than anything else I've ever used.
Granted the Black Fire sio2 Sealant is what we're talking about now and my friend started using that since he coundn't get the Crystal Seal.
His car is also Shark Gray and it looks just as good if not better and holding up just as well.
The Crystal Seal was spray on, wipe around, leave it, and done.
Reading up on Black Fire sio2 Sealant, it's spray on, wipe it around, then wipe with a clean dry towel.
I'll be getting the Black Fire sio2 Sealant when I run out of the Crystal Seal
Dif is offline
The Following User Says Thank You to Dif For This Useful Post:
Old 11-19-2018, 03:43 PM
  #33
gmarcucio
CF Senior Member
gmarcucio's Avatar
OP so you purchased the Blackfire polish or the paint sealant?
gmarcucio is offline
Old 11-19-2018, 03:44 PM
  #34
devnull
CF Senior Member
devnull's Avatar
St. Jude Donor '07-'08-'10, '14
DANG CHIP! Yeah this stuff is fantastic...
THANKS for the tips dude!
Driverís door reflecting her car, then the hood reflecting the house LOL...
devnull is offline
The Following User Says Thank You to devnull For This Useful Post:
Old 11-19-2018, 04:23 PM
  #35
CCA Corvette Parts
Regards
Chip
__________________
Old 11-19-2018, 04:25 PM
  #36
CCA Corvette Parts
It's as easy as using detail spray...
Regards
Chip
__________________
The Following 2 Users Say Thank You to CCA Corvette Parts For This Useful Post:
devnull (11-19-2018), Vet Interested (11-19-2018)
Old 11-19-2018, 04:32 PM
  #37
devnull
CF Senior Member
devnull's Avatar
Regards
Chip
yup, I can testify!
long time Zaino guy here (before ZFX days). This stuff was like Z6 easy!
devnull is offline
Old 11-19-2018, 04:35 PM
  #38
Vet Interested
CF Senior Member
Wonder if I should hold off for Black Friday?
Old 11-19-2018, 04:53 PM
  #39
CCA Corvette Parts
I was hoping you would post up some BLUE pics
Looks amazing
Chip
__________________
The Following User Says Thank You to CCA Corvette Parts For This Useful Post:
Old 11-19-2018, 05:09 PM
  #40
Inferno18
CF Senior Member
Inferno18's Avatar
I would. I bought mine on Veterans Day and they were running a 25% off store wide plus they threw in 3 supreme 530 microfiber towels (value $18.00) for free. I paid $36.00 for everything plus $5 shipping.
Quick Reply: Just a little BlackFire for you
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
