Blew Coolant Line
Blew Coolant Line
I was in a parking lot today when suddenly an overheating alarm went off and the temp guage zoomed to 260. I immediately shut off the car and opened the hood. There was a black hose under and next to the fuse box spewing hot water all over. Luckily, I was not on the freeway. Any idea what may have happened? Had it towed to the dealer.
There have been a number of cases, including my 2014, where the cooling fans are not running at the time the car overheats. Once you turn the car off and back on, it corrects itself. No codes so the dealer can't easily diagnose. They never did resolve the issue on mine before I traded it.
Happened 3 times. They never fixed it. I ended up trading the car. The fan needs to be replaced but you will probably have to pay for it. Several people have upgraded to the Z06 fan which runs about $300.
I had a few times....rogue temp spikes. But NEVER got any other warning. Just the analog needle spiking...waaaay up there. Dealership looked at it a few times.
Hasn't happened in over a year. I guess just a lost electron wandering around in there? Was so bizarre. Never had fluid spewing though.
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Rebel Yell (12-07-2018)
Blew Coolant Line
Did the coolant line enjoy it?
Sorry; i tried to resist posting this, but I couldn’t.
GundamX7X (12-08-2018)
Originally Posted by PatternDayTrader
So next time the temp gauge is creeping up past where it normally runs, turn on the ac and listen for the fans.
The point is if the temp gauge is moving up into the abnormal range, then turn on the ac, if the fans come on then its likely no further action will be required. If the fans don't come on and temp continues to climb, then shut the car off so you don't fry the engine, using your description.
If the fans are not on then it will overheat. If it overheats, then turning the ac off reduces the load on the engine.
