Winter Road Trip with salty roads
The base tire can handle the trip, without any drama, very easily. The "Cup" tire by the way is not the same tire as the base tire found on the GS (non Z07). Seems you're not aware of this. Traction with the Cup tire is questionable in bad weather. BTW, daytime high temperatures in the 30s are "not" below freezing temperatures. Thanks for your compliment.
I'd trailer it if possible. Even a U-haul truck/open trailer would be better than trying to drive in unknown weather conditions.
An enclosed trailer would be the first choice, with an open trailer coming in a very distant second place. If you do open trailer, be sure to wash the underside just as well as you would have from driving it.
Trailering it avoids any issues with summer tires running cold on cold roads, and any potential lack of grip issues due to wet/cold weather conditions.
Two weeks ago I drove my new GS from the Corvette museum 680 miles through light snow, sleet freezing rain and salted roads conditions in temperatures in the low 30s to my home in Virginia. I had used MRC Weather mode and the traction control performed great. While I would not recommend Vette owners do this regularly the car can handle these conditions without drama. OK, you may now return to your panic attack which I had rudely interrupted.
Received 2,225 Likes
Just drive the damn thing home carefully. All this crap worrying about road salt is just that, crap. If you people knew anything about how aluminum holds up to salt you would realize that it's not an issue. Remember our cars are for the most part aluminum and plastic.
I’m not saying that there is no downside to driving on salt covered roads and exposing our aluminum frames to road salt. BUT aluminum corrosion is far different than rust on iron and steel. The oxidation that occurs on aluminum from salt creates a protective coating that strongly adheres to the aluminum unlike the rust on iron and steel that flakes off. That protective coating of aluminum oxide prevents further oxidation of the aluminum. For the effect to harm aluminum the salt must be present for a long period of time and be in a moist (high humidity) and warm environment. Running the car through a car wash that sprays the underbody or just driving in the rain will remove any salt buildup.
https://www.washingtonpost.com/local...=.715e3d7e15a9
I have concern about non-aluminum parts on the Corvette. Brakes, rotors, suspension parts, exhausts are not made from aluminum so those components should be a consideration for corrosion as well.
Brakes and rotors get changed out regularly so why worry about a little corrosion. Suspension parts if you haven't looked are aluminum. Exhaust and mufflers are 409 stainless steel and very resistant to corrosion. When's the last time you had to replace those?
#34
9 deg. F is the lowest I've driven my C7. PSS not Sport Cups, but stuck it in W and was gentle on the go pedal. Nothing wrong with driving in the rain or taking it through a touchless wash with a good undercarriage spray. I've got 250,000 miles on a C6 regularly abused this way.
eta: I drove in the snow, today.
#37
The car can handle it. I drove on salted roads and ice in my C6 and just did an under carriage wash after things cleared up. Sold it at 80 k miles zero issues. I just got home from an 80 miles trip in a few inches of snow in my C7 and it survived.
Honestly it is sort of fun driving it in crappy weather.
#38
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
#40
Something else to keep in mind while driving in the rain. You get the most legitimate test for water leaks (into the interior) that can possibly occur. I cant say emphatically enough, no one wants to find out about a water leak after their warranty expires.
Carvin (12-10-2018)
