PDR SD card
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
You have to format it FAT32. I don’t know how many times this needs to be repeated.
Some cards don’t come formatted, or they’re formatted NTFS because FAT32 is an OLD standard. No Windows 10 machine can natively format FAT32, you need an app like Rufus if you have Windows 10, or throw it into another machine/camera/whatever that can format it, as most cameras format in FAT32.
I do a lot of Linux images on SD cards so know them pretty well
Have you tried formatting your 32GB card just for kicks & grins to see if works after that? The worst that can happen is that it still won't work.
Perhaps you just have a bad card. Or maybe something is wrong with your PDR, who knows. Most people seem to have no issues with a 32GB card right out of the box. I can't comment on that since I've never used a 32GB card. The larger cards 64GB, 128GB etc...definitely need to be formatted with an app like the one I sent to you before they will work with the PDR.
I downloaded the software but can't find my sd card once it is plugged in to my Dell with windows 10. I've been to file manager, looked at devices, found my c drive but no sd drive. I'm sure 'the Hack' is rolling his eyes and I can usually figure out this stuff, but i'm at a loss with this one. I'm thinking I'll just pick up a card from Amazon just like the one a previous poster said worked out of the box.
Computer literacy is HARD.
How are you plugging your SD card into your Dell PC? Does the Dell have a SD card reader slot, or is it via a third party USB SD card reader? Do you have another SD card to test?
I'm not an IT expert, nor am I particularly adept with a computer. Take everything I have to say with a grain of salt. But if you eliminate all the possibilities, whatever remains, however improbable...Blah blah blah.
Even if the card is formatted in a form that a PC wouldn't recognize, under Windoze 10, if you insert a USB drive or card that is formatted in an odd format (Apple HFS, for example) the operating system is going to ask you if you want to format it into something that it will recognize. If there are no partitions or the card is unformatted, the operating system is going to ask if you want to format it into something it will recognize. At this point, if you insert the SD card correctly and the computer just sits there and acts like a brick, the next course of action to eliminate the possibilities would be to get a WORKING SD card to test.
Maybe it's time to go out and buy a lottery ticket, in my 10+ years of using a variety of portable solid state media (CompactFlash, USB key, USB drives, SD cards etc) the last time I had a device fail was about 8 or 9 years ago, and that's over hundreds of write cycles. Having one fail out of the box is about as rare as winning a lottery ticket (not the big jackpot kind, I'm talking about the $2 dollar scratcher to win $4), but that's entirely within the realm of possibility.
Sorry for being a d*ck, by the way.
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Good thread. Had similar issues with a 64GB SD card that was previously used in my Cannon camera. No SD reader in my PC so I couldn’t reformat. Bought a new 32GB card at Wally for $9.50 and it works like buttah !
I use windows 7 and all you have to do is insert sd card (I am using a stick instead for demonstration purposes) right click the sd card and it will ask to format, hit format and you will get this, hit start and your done in 2 seconds.
need-for-speed (08-04-2019)
