DI oil deposits, catch can, exh extraction, meth kit
I think I saw it some place the 2014 had a poor set up for a PCV system and after that G,M, per say worked on it and it done much better. Plus I know G.M. had a bad batch of blocks in 2014 that the blocks wasn't set up that good and really needed to be bored like 5,k to fix the problem. This caused a bad blow by on the oil problem into the intake and that.
I know this from what Andy from A/A got one or two of these early c7's in his shop. But even in the later c7 with so called better PCV system if I had any type of blower on the car. No way I would run it without a good catch can on the car.
Now with all the post above & me also if you want one are think you need one get one, If you dont think you do then run the car without one your car do what you want and just have fun in it.. Robert
Man I get off topic easily. lol Thanks for the info that is now bugging me about the motor. lol
Edit: Visited a friend and his 18 GS with only 2k on the clock had the same odd sound as mine so I think it is just a C7 noise and nothing to worry about after all. I did find that his seat bottoms feel way different, in a good way, his traction control allowed for way more wheel spin than mine, his ride in sport was softer, and his NPP exhaust behaved different and didn't go quiet like mine in sport. Interesting stuff.
I watched this at 2X speed as there is no need to wait through the whole vid at real time. I think I am just going to play with making one after hours at work if I can. Wished I had a TIG at home, but having a machine shop and welders at work is still a good thing.
